Author Topic: Headlight relay upgrade  (Read 21127 times)
Offline tommyg29
« on: January 09, 2015 - 10:54:06 PM »
Finally pulled the trigger a few weeks ago and ordered the relay kit made by Rob Yule. Very high quality kit that took me a few hours to install, but I think well worth it. Before I was getting dash flicker and now....none. Plus my headlights and dashlights are much brighter, and I used the occasion to repair my headlight trim rings (a mount hole in my grill was broken so fixed it with epoxy putty) and aim them properly (against the garage door  :bigsmile:).
I am also adding a new vintage am-fm radio soon (it should arrive any day) so my electrical upgrades for the year should be complete in January!
Before and after:
« Last Edit: January 24, 2015 - 09:32:30 PM by tommyg29 »
Re: Headlight relay upgrade
« Reply #1 on: January 10, 2015 - 09:18:56 AM »
Looks good   :thumbsup:
A bit surprising that the ammeter is showing a little discharge with the tach at 2200rpm. I'm guessing it has been bypassed? If the ammeter is still in the circuit (not bypassed) you might want to go over your connectors and make sure they are not dirty/corroding.  :2cents:
Offline roadman5312
« Reply #2 on: January 10, 2015 - 09:22:17 AM »
Tommy, can you post a link for that relay kit. I would like to order one. Thanks  :thumbsup:
« Reply #3 on: January 10, 2015 - 09:23:52 AM »
Looks good! Nice to see you driving it again too!  :2thumbs:
Offline dougs bs23
« Reply #4 on: January 10, 2015 - 10:20:41 AM »
is this the same kit as talked about in the archives section from the guy at FABO?
Offline tommyg29
« Reply #5 on: January 10, 2015 - 11:32:14 AM »
I reached Rob through A bodies only and contacted him by email. He custom made it for my 4 light e-body.
I did the alternator bypass 4 years ago, so the ammeter doesnt read accurately.
http://www.forabodiesonly.com/mopar/showthread.php?t=216514
Basically, I have the relays mounted under the battery tray, right next to my msd box, and a pair of 12g wires run from there back to the firewall, across, and then over the passenger valve cover to the alternator post. There are three ground wires, and two pairs of headlight wires, different lengths, to run through the rad support and over to behind the light buckets. Remove trim rings and unplug existing lights. Replug them into the new sockets, and finally plug the "trigger" wire into the old socket that your left drivers low beam was plugged into, and youre done. All my old wiring was left in place, tucked out of sight for the most part.
Its great to have it running again, and running well to (knock on wood). Taking it to a cruise in tonight and cant wait for the new radio. Should be nice 76 degree weather tonight  :bigshades: :burnout:
« Last Edit: January 10, 2015 - 11:45:27 AM by tommyg29 »
Offline roadman5312
« Reply #6 on: January 10, 2015 - 11:49:11 AM »
Thanks   :2thumbs:
Offline HP_Cuda
  • Mopar or No Car!
« Reply #7 on: January 10, 2015 - 04:18:01 PM »
I'm a bit impressed with how bright the lights are now, guess that tells you how much resistance is in the original setup.
Glad to hear the 71 is running good again, I know how frustrating it can be to chase a problem for awhile.
 :2thumbs:
« Reply #8 on: January 12, 2015 - 08:15:29 AM »
This is the way modern headlights are all wired now , using a low amp circuit to switch the relay &  send  battery power directly to the headlights , it never made sense to run all the power through the firewall & the headlight switch & back through the firewall to the headlights ! The headlights better be brighter as more current will be getting to the lights now !
Offline crackedback
« Reply #9 on: January 12, 2015 - 11:03:08 PM »
Tom,
First - the car looks great, nice ride!
Thanks for the positive review.   I was planning on following up with you regarding receiving the kit and install.  Glad it worked well for you and you are happy with the kit!
I'm still building these kits and I'm not here much.  Easiest to reach me on FABO or my e-mail
robule1 at yahoo dot com
Everyone that's installed my kits has been happy with the results and like the additional light output.  It always good to see where we are going!
Thanks to the mods for letting me post here with my product.
« Last Edit: February 15, 2015 - 04:43:14 PM by crackedback »
Offline maddawg57
« Reply #10 on: January 18, 2015 - 10:25:05 AM »
I just ordered a kit from Rob . I will let you guys know my results . I haven't read a bad thing about his kits . I've done this to a few cars that I have had in the past and know that it makes
a big difference. Rob makes it so much easier . I don't have to round up the parts , cut the wiring ,and so on just mount the relays plug it up and hookup the ground and power . The only
way it would be easier is if he included installation too lol. While I'm installing my kit, I'm also going to run my alternator to the starter relay , bypassing the amp meter.
Offline crackedback
« Reply #11 on: January 20, 2015 - 08:31:14 PM »
Your kit left today.  I forgot about the Monday holiday.
Thanks again for the purchase.
Offline BS CUDA
« Reply #12 on: January 20, 2015 - 09:59:29 PM »
This kit has become real popular it seems. I believe Rob shipped mine today - possibly tomorrow.    :cooldancing:
Offline ToxicWolf
« Reply #13 on: January 20, 2015 - 10:11:21 PM »
Hey Tommy
Are you getting your radio from AAR in Tampa?
Offline tommyg29
« Reply #14 on: January 20, 2015 - 10:18:27 PM »
Hey Tommy
Got it today and started the install by removing the aftermarket Pioneer unit. Took me 45 minutes to get it out!
Found out my two little front dash speakers werent plugged in (and are no good anyways) so I need to go out and pick up a couple 3.5 or 4 inch speakers before I put it all together. That will give to two fronts and two rears.
Probably just going to buy some generic pair from best buy.
