Author Topic: Headlight relay upgrade  (Read 21125 times)
Offline ToxicWolf
Re: Headlight relay upgrade
« Reply #15 on: January 20, 2015 - 10:22:09 PM »
Got it today and started the install by removing the aftermarket Pioneer unit. Took me 45 minutes to get it out!
Found out my two little front dash speakers werent plugged in (and are no good anyways) so I need to go out and pick up a couple 3.5 or 4 inch speakers before I put it all together. That will give to two fronts and two rears.
Probably just going to buy some generic pair from best buy.
That's great.  Had problems gettings ours to work until we figured out the front speaker was shorted to the dash frame.   :banghead: :roflsmiley:
Offline crackedback
« Reply #16 on: January 21, 2015 - 01:19:05 PM »
This kit has become real popular it seems. I believe Rob shipped mine today - possibly tomorrow.    :cooldancing:
Your kit left yesterday as well.   I may owe you a couple bucks back on shipping.  Let me know when it arrives and we'll get that squared away.
The mail guy that is filling in for the regular lady sucks at scanning shipments.  I'm hoping the tracking starts showing up for your delivery.
« Last Edit: January 21, 2015 - 01:25:07 PM by crackedback »
Offline maddawg57
« Reply #17 on: January 22, 2015 - 07:46:10 PM »
Received my kit today, looks great. Don't know when I will get a chance to install but will post results when I do . Thanks Rob good job . Bob
Offline crackedback
« Reply #18 on: January 22, 2015 - 08:25:57 PM »
Could you do a before and after running at night?    I know the weather can be a bit difficult to maneuver around.
Thanks again and if you have any question, drop me a PM.
Offline Cudaragtop
  • Woulda Shoulda Cuda! Randy
« Reply #19 on: January 22, 2015 - 10:00:03 PM »
 :popcorn:
- Randy D.
1 of 88 1970 340 4-Speed 'Cuda Convertibles
69 Barracuda Fastback Project Album https://goo.gl/photos/XjsAsx4LDo7psimU8
----o00o--'(_)'--o00o----
Offline crackedback
« Reply #20 on: January 22, 2015 - 10:44:12 PM »
:popcorn:
Randy?
Did you get your tracking info?  If not let me know and I'll get it for you.
Shows it should have been delivered today.
« Last Edit: January 22, 2015 - 10:47:03 PM by crackedback »
Offline BS CUDA
« Reply #21 on: January 22, 2015 - 10:59:50 PM »
Rob - don't worry about the change - we're good. Looking forward to this upgrade.
Offline Cudaragtop
« Reply #22 on: January 22, 2015 - 11:05:22 PM »
Randy?
Out your door on Tuesday and in my hands on Thursday!  :2thumbs:
The Kit looks good Rob. Thanks!
I'll post up some pics when I get around to installing.
- Randy D.
Offline dougs bs23
« Reply #23 on: January 23, 2015 - 05:43:26 PM »
ordered this kit also.   :cooldancing:
Offline annularnos
« Reply #24 on: January 24, 2015 - 12:41:14 PM »
Rob, what's the best way to order a kit? 1971 Cuda with factory road lamp option.
John
Offline crackedback
« Reply #25 on: January 24, 2015 - 01:43:38 PM »
John
John,
Best to E-mail me.  robule1 at yahoo dot com
I haven't done anything with the road lamps.  I believe the lamps are factory installed using a relay.  The wiring could be improved to increase performance.  I'll have to look at a wiring schematic to come up with an approach.  Bulb connections may be another potential hurdle.  With a little research, if the products are available, I can design a viable and improved approach.
Offline BS CUDA
« Reply #26 on: January 31, 2015 - 03:49:57 PM »
 Received the kit yesterday - looks absolutely fantastic - well built - very professional looking. Will install in the next few weeks.  :worshippy
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #27 on: January 31, 2015 - 04:15:02 PM »
John,
Rob, I would be potentially be interested in one for a '70 Cuda with road lamps too.  Keep us up to date if you come up with a solution.
Offline crackedback
« Reply #28 on: January 31, 2015 - 08:47:03 PM »
I think John and I have figured out the 71 switching situation, a relay solution for 71 cars is done.   I asked John to get some pictures of road lamp light plug inside your housings.   I assume, I know dangerous, that 1970 use the same internal attaching plug.   Once I know that plug, I can get a road lamp kit together using larger sized wire.
On a 1970, being a single headlight per side, I believe that you can run your road lamps with the car on high beam setting.  Is that correct?  There is no switching off of your road lamp when you go to high beams?   I think that is a fed regulation about not having more than 4 forward light illuminated at any time.  71's have to switch off the road lamps, otherwise they have 6 lights.
If you have any pictures of your lamps taken apart and the internal connectors, I'd love to have them for reference.  John's as well.
Please let me know the answers and any pictures and we can get a solution for 70 & 71 road lamp cars.
Performance for all the lights should increase dramatically.
Offline crackedback
« Reply #29 on: January 31, 2015 - 08:54:01 PM »
BS Cuda,
Thanks for the positive feedback.  Good to read it got to you.  I really dislike the lazy replacement mail guy, one try scanning tracking and done.  He did it again on another package to Canada.
If you have any question please let me know.  Install should take 2 hours top if you go methodically and sipping a beverage.  Most have them installed in under 1.5 hours.  One customer had it done in 45 minutes.
« Last Edit: January 31, 2015 - 09:11:27 PM by crackedback »
