Author Topic: MSD location  (Read 3391 times)
MSD location
« on: January 10, 2015 - 09:11:23 AM »
Considering moving my MSD module off the firewall and into the trunk. Has anybody experienced any ignition issues caused by long run of wire between ECU and distributor?  :dunno:
Offline dfrazz
  • 1970 Cuda - 1968 Charger
Re: MSD location
« Reply #1 on: January 10, 2015 - 01:37:47 PM »
I moved my MSD along with my battery to the trunk of my '71 Challenger and had no issues at all.
Offline vinb
Re: MSD location
« Reply #2 on: January 10, 2015 - 01:51:07 PM »
Got mine under the battery tray, no issues with the 6 box , but the 7 box does not like heat.
Re: MSD location
« Reply #3 on: January 10, 2015 - 03:24:08 PM »
Any pics of how you mounted it?
Offline dfrazz
Re: MSD location
« Reply #4 on: January 11, 2015 - 11:23:11 PM »
I mounted it in the corner of the trunk on the drivers side.  Then I mounted the battery to the inside to hide the MSD box.  The other part mounted there is my brake booster vacuum pump.  I ran all wiring through a loom out of the trunk through a drain plug, inside the rear quater panel, along the frame rail, up through the splash guard in the front inner fender into the engine bay.  I ended up moving the starter relay down to the lower corner of the firewall to further hide the wiring, and ran all necessary wiring on the firewall through a black loom.
Offline cudagirl4406pk
    • Garageartmusclecars
Re: MSD location
« Reply #5 on: January 15, 2015 - 07:01:45 AM »
My MSD is under my battery tray out of sight
michele
Offline Bart
Re: MSD location
« Reply #6 on: January 15, 2015 - 12:56:06 PM »
Put mine in the glove box
1970 Cuda 383
2008 Titan
2010 G37s
1996 Advantage Victory 27 502ci
2013 HD Roadking
Re: MSD location
« Reply #7 on: January 15, 2015 - 04:15:03 PM »
michele
Same here.
Offline TelisSE440
Re: MSD location
« Reply #8 on: March 15, 2015 - 11:53:11 AM »
I have put it under the dash, next to the radio, which I don't use.
Offline cordodge
Re: MSD location
« Reply #9 on: March 15, 2015 - 12:41:43 PM »
Here is what I did, have a shut off and the ford style solenoid on the bracket as well
1970 challenger 95% done
1969 roadrunner in progress
1969 D-100 13,000 mile truck
1969 L-700 tilt cab in progress
2007  Dodge Ram 4x4
2017 hyundia Santa fe ultimate
1977 VERY UNDERSTANDING WIFE !! 😇
Offline 67vertman
  • Member since 9-23-2005
Re: MSD location
« Reply #10 on: March 15, 2015 - 02:50:41 PM »
Mine is hidden under the dash, behind the instrument lights by the emergency brake, then I ran the wires out with the wiring.
Offline crackedback
Re: MSD location
« Reply #11 on: March 15, 2015 - 04:55:24 PM »
If the battery is back there it's not a big deal.  The only concern I'd have is length of run for the msd power and ground wires.  I'd go overkill on sizing the wire if the MSD is in the trunk and battery up front.
Good thing, msd 6 style boxes only draw about 1 amp per 1K rpm.
Offline HP_Cuda
  • Mopar or No Car!
Re: MSD location
« Reply #12 on: March 16, 2015 - 03:36:29 PM »
I guess MSD must have extra long distrib hookups otherwise it would be a pain to make one that long.
