Author Topic: Stock Suspension Equals Wheel & Tire Size Help  (Read 5920 times)
Offline flagcraig
« on: January 10, 2015 - 12:25:46 PM »
I read through the tire combo post a few times but I just need to be sure.
Will the following fit my 1972 Dodge Challenger Rallye with stock (restored with new parts) suspension?
Front: 17 x 8 wheels BS 4.25" with tires at 245/45R/17
Rear:  17 x 9 wheels BS 5" with tires at 275/40R/17
I would prefer not to do any modification to the suspension.  These would be the Year One Rallye wheels.
Thanks.
Offline crash340
Re: Stock Suspension Equals Wheel & Tire Size Help
« Reply #1 on: January 10, 2015 - 07:00:08 PM »
Dont see why not, a little less BS on the rears maybe better,
Greg
73 Cuda
Brisbane, Australia
Offline E-Body Products
  • E-Body Products
    • E-BODY PRODUCTS
« Reply #2 on: January 10, 2015 - 07:53:03 PM »
Yea, you might need a B-Body rear to pull off that 5" backspace.
E-Body Products
www.ebodyproducts.com
606-481-9014
Offline Cudaragtop
  • Woulda Shoulda Cuda! Randy
« Reply #3 on: January 11, 2015 - 12:32:43 AM »
Thanks.
That is the exact setup I am running without any mods to the suspension on my 'Cuda.
Year One Part Number: MRWSL1
Firestone Firehawk Wide Oval Indy 500 tires from Tire Rack.  :2thumbs:
http://www.tirerack.com/tires/tires.jsp?tireMake=Firestone&tireModel=Firehawk+Wide+Oval+Indy+500&partnum=74WR7FHWI5&i1_Qty=2
http://www.tirerack.com/tires/tires.jsp?tireMake=Firestone&tireModel=Firehawk+Wide+Oval+Indy+500&partnum=445WR7FHWI5&i1_Qty=2
For your 72, I guess you would want Acorn Centers though: Part Number: MRWSL2
« Last Edit: January 11, 2015 - 01:16:50 AM by Cudaragtop »
- Randy D.
1 of 88 1970 340 4-Speed 'Cuda Convertibles
69 Barracuda Fastback Project Album https://goo.gl/photos/XjsAsx4LDo7psimU8
----o00o--'(_)'--o00o----
Offline crash340
« Reply #4 on: January 11, 2015 - 04:04:33 AM »
A B Body rear has its springs 1" inboard compared to an E Body however the axles are only 3/4" shorter approx, so by going to a B Body diff only gives you roughly 1/4" more wheel clearence than an E body housing. what it does give you is a wider wheel or more guard clearance.
Greg
73 Cuda
Brisbane, Australia
Offline flagcraig
« Reply #5 on: January 12, 2015 - 11:10:15 AM »
On Year One web site these are the tire sizes they have verified will fit a stock suspension and brakes with the wheel sizes I have chosen.
Now I have to decide do I go this route or the Magnum 500's with 15x7's and 15 x8's.
Mr. CudaRagTop do you have any pics of the rear look?
Thanks.
Offline Cudaragtop
« Reply #6 on: January 12, 2015 - 09:51:21 PM »
Thanks.
Pictures from April 2014
- Randy D.
Offline flagcraig
« Reply #7 on: January 13, 2015 - 11:05:58 AM »
Looks great!  I am going to go with the acorn centers that originally came on the car with your exact specs.
Thanks again.
  • E-Body Products
    • E-BODY PRODUCTS
« Reply #8 on: January 13, 2015 - 05:14:41 PM »
B-Body Rear with 15x10 Rim
E-Body Products
606-481-9014
  • E-Body Products
    • E-BODY PRODUCTS
« Reply #9 on: January 13, 2015 - 05:15:48 PM »
E-Body Products
606-481-9014
Offline crash340
« Reply #10 on: January 13, 2015 - 06:35:44 PM »
These are 18x10 on rear with 5 1/2" BS (these rims are actually 6" BS but there is only about an 1/8" spring clearance with about an inch of factory fender lip clearance so going to 5 1/2" BS would be good), stock suspension
Greg
73 Cuda
Brisbane, Australia
Offline flagcraig
« Reply #11 on: January 23, 2015 - 11:24:02 AM »
Pulled the trigger on the Year One 17 wheels.....Rallye's.  Firestone was unavailable locally so they cut me a deal on Nitto's.
Now we try them on next week and hope they fit.
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #12 on: January 25, 2015 - 10:22:07 AM »
Your are going to love the Nitto's!
Offline Mopar Mitch
« Reply #13 on: January 27, 2015 - 02:12:49 PM »
I suggest just getting the Year One 17x9 for BOTH the front and rear... they'll fit A-OK... and with 275-40-17 tires BOTH front and rear.  Having different size f/r rims/tires is a disadvantage if/when you'll need to rotate them.  Plus, the 275-40 in the front will make the car look much more awesome, as well as handle better overall.  If you wanted, you could even get a 5th identiacl rim/tire for use as a spare in the trunk.
 :2cents:
Offline challenger_affair
« Reply #14 on: January 28, 2015 - 12:28:34 AM »
I got the year one ralleys late last year, they look awesome!  My car has stock suspension, old and in moderate disrepair  :(
I ended up going with the 17x8's all around for a few reasons, I preferred to use a 50 series tire to maximize tire sidewall height both for looks and ride quality instead of something like 275/40's, so the 17x9's didn't seem necessary.  I think I also read somewhere on here that the 17x9's may result in some possible front end clearance issues on the inside edge.
For tires I got Kumho Ecsta ESP 235/50 front and 255/50 rear.  I think they look pretty good and they have the correct weight rating for the car.  235/50 was about as tall a tire it seemed would fit up front, and 255/50 allowed me to get a bit more width in back without having too much difference in size front to back.  Would have preferred to run the same size all around, but again its all trade off's for one reason or another based on personal preference.
Ultimately I'm happy with the choices.  I had to raise the front a bit to make the fit, but I think I still have some room left on the outside to upgrade to disc brakes, which need a little extra room.  The driver side rear is very close to the wheel well, but so far so good.  The rear leaf's are old and will be replaced eventually so I'll have a little more room at that time...   :2cents:
« Last Edit: January 28, 2015 - 12:34:49 AM by challenger_affair »
1970 Challenger 383 RT Auto Plum Crazy
