Author Topic: 8 3/4 rear end identification  (Read 3941 times)
Offline 4Cruizn
  • HEMI FISH
« on: January 11, 2015 - 12:18:39 PM »
Do the numbers on the side of the pig indicate what gear ratio it is?   :clueless:
Offline BIGSHCLUNK
Re: 8 3/4 rear end identification
« Reply #1 on: January 11, 2015 - 12:22:09 PM »
That would make things easy now wouldn't it?   :dunno:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline mrbill426
    • All Around Mopars
« Reply #2 on: January 11, 2015 - 12:52:32 PM »
No, they put a metal ratio tag under one of the upper carrier-to-housing retaining nuts.  If it is missing you can still rotate the input pinion and count the revolutions it takes for the wheel to make to make one complete turn, then do the math.
 :working:
MOPAR or NO car!
'72 'Cuda 340, white on white
'72 Sebring; bracket project
'66 Imperial Crown; parts car
Offline HP_Cuda
  • Mopar or No Car!
« Reply #3 on: January 11, 2015 - 01:58:06 PM »
Short answer = yes
Otherwise someone may have swapped out the pig/chunk and kept the tag there and hence will be wrong.
Offline 4Cruizn
  • HEMI FISH
« Reply #4 on: January 11, 2015 - 02:03:28 PM »
Short answer = yes
So pretty much need to pull the pig out and do the math to be sure . . . . What is the formula to determine what it is?
Offline HP_Cuda
  • Mopar or No Car!
« Reply #5 on: January 11, 2015 - 02:15:59 PM »
You need to put the rear up in the air and rotate one of the tires and see what the other tire is rotating to said ratio.
Good read and also goes over open rears vs limited slip:
http://www.how-to-build-hotrods.com/gear-ratio.html
Offline mrbill426
    • All Around Mopars
« Reply #6 on: January 11, 2015 - 02:33:44 PM »
I am pretty sure that you simply divide the wheel rotation by the pinion rations, if you have 4 pinion rotations to achieve 1 wheel rotation, you have  a 4 to 1 gear ratio.  The closest Mopar gear-set would be a 4.10.
Am I off base guys???  :1zhelp:
 :working:
MOPAR or NO car!
Offline jhaag
« Reply #7 on: January 11, 2015 - 03:04:54 PM »
MrBill is correct. Very simple equation.
love 70 Challengers
Offline 4Cruizn
  • HEMI FISH
« Reply #8 on: January 11, 2015 - 03:28:08 PM »
Ok that sounds pretty easy but what if the pig is for sale at a swap and not in the rear?
Offline falkenracing
« Reply #9 on: January 11, 2015 - 03:39:22 PM »
The ratio is stamped on the ring gear if I'm not mistaking, so if it's out, you will be able to see it.
Offline BIGSHCLUNK
« Reply #10 on: January 11, 2015 - 03:42:58 PM »
Divide the ring tooth count by the pinion tooth count....  :grinyes:   Originally I thought you wanted to know by looking at the embossed numbers on the casting. Ya, I know tags can be long gone!
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline 4Cruizn
  • HEMI FISH
« Reply #11 on: January 11, 2015 - 04:18:40 PM »
That was my initial question, I am currently tearing one apart . . . My first . . . And just assumed that the numbers on the outside of the center section would tell you the gear ratio.  I have already pulled the axles but assume I can just stick one back in and make a revolution to determine ratio.  I think I was told it is a 3.55 ratio.
Offline jhaag
« Reply #12 on: January 11, 2015 - 04:39:05 PM »
Put a mark on the ring gear. put a mark on the pinion yolk. rotate the ring gear 1 revolution and count how many times the pinion yolk goes around. 3.5 rotations of the pinion yolk and it is a 3.55 to 1. Easy peasy. Ratio will also be stamped into the ring gear. casting numbers on the carrier have nothing to do with gear ratio.
love 70 Challengers
Offline BIGSHCLUNK
« Reply #13 on: January 11, 2015 - 05:23:46 PM »
I;ve had times that the spin and count method can be a little tricky. EXAMPLE... 3.23 -3.55 like a hair of a turn.....
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline anlauto
« Reply #14 on: January 11, 2015 - 05:32:18 PM »
I've always found it easier to leave the rear wheels on the car. Do one full rotation of the wheel and count the rotations of the yoke. 3:23's would be 3 1/4 while 3:55's would be 3 1/2, pretty easy to tell the difference.
