Author Topic: 8 3/4 rear end identification  (Read 3940 times)
Offline mrbill426
    • All Around Mopars
Re: 8 3/4 rear end identification
« Reply #15 on: January 11, 2015 - 05:56:38 PM »
I've always found it easier to leave the rear wheels on the car. Do one full rotation of the wheel and count the rotations of the yoke. 3:23's would be 3 1/4 while 3:55's would be 3 1/2, pretty easy to tell the difference.
MOPAR or NO car!
'72 'Cuda 340, white on white
'72 Sebring; bracket project
'66 Imperial Crown; parts car
Offline blown motor
« Reply #16 on: January 11, 2015 - 08:31:00 PM »
That's how I did mine.
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #17 on: January 11, 2015 - 10:39:36 PM »
I agree with the wheel turn method, but Cruzin said the rear is apart.  The correct gear ratio should be stamped on both the ring and pinion.  The number on the case ending in 741, 742, 489 only tell you the size and type of pinion (http://www.mymopar.com/Mopar8_75RearEndGuide.htm).
« Reply #18 on: January 12, 2015 - 12:06:02 AM »
counting revolutions of the pinion yolk ONLY works if either both wheels are turning equally as in sure grip or if one wheel is held still & you turn the wheel 2 full revolutions otherwise it can be inaccurate
