Author Topic: Pistol Grip Shifter ?  (Read 5026 times)
Offline HP_Cuda
  • Mopar or No Car!
Re: Pistol Grip Shifter ?
« Reply #15 on: January 29, 2015 - 09:43:34 PM »
Cool Bob, I'll head over when I want to rebuild mine!!!
 :bigsmile:
The shifters are easy to rebuild.The full kit is about 100 bucks.I have done 3 of them.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #16 on: January 29, 2015 - 09:44:34 PM »
I would go for option 4 , pull it out go through it & see how it works cleaned up & adjusted properly , no cost & if it needs parts you know what you need to replace !!
Offline 73440
« Reply #17 on: January 30, 2015 - 12:02:11 AM »
Thanks,
Good to know about the reverse adjustment.
Don't use it much so I wasn't too worried about adjusting, just dealt with it, knew how to get reverse.
As I told my sister-in-law when she was trying to tell me how to stop while skiing,
"I don't want to know how to stop, I want to know how to go fast"
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline 73EStroker
« Reply #18 on: February 06, 2015 - 02:17:45 PM »
Original car? Rebuild everything. Hurst sell the rebuild kit along with others like Brewers. And put new linkages in as well. Selector levers are real hardend steel so should be ok.
Barry (Salmon Arm)
Offline Cruzin
  • I love YaBB 1 Gold!
« Reply #19 on: February 20, 2015 - 05:03:04 PM »
BadJoey,  Just to clarify, did this shifter use to perform well and for whatever reason, now it's not?  Or, is this a problem that you are not well familar with and are trying to figure out where to start?
The reason why I ask is because I went through a similar situation.  The problem ended up being a collection mis-matched parts from various B and E-body linkage operating levers, linkage rods, and shifter mechanism.  Once we obtain the correct parts the car shifts perfectly.
