Author Topic: Pistol Grip Shifter ?  (Read 5029 times)
Offline BadJoey
« on: January 15, 2015 - 01:17:34 PM »
Hey guys . I have a 70, 440 Challenger 4 speed with the original shifter . Seems I recall hearing the shifters look good but do not shift very well . Mine shifts like crap . Does not go in and out of gear very well and I have to fight to get in reverse . Do you think it is just my adjustment or  do the shifters stink . If I replace it any sugestions ? Thanks guys thinking spring .
Re: Pistol Grip Shifter ?
« Reply #1 on: January 15, 2015 - 01:21:17 PM »
Nothing wrong with the pistol grip / Hurst unit , but after 40+ years they need to be disassembled cleaned rebuilt with new grease & adjusted , so you need to remove it & service it , Hurst does sell new units if you decide to replace the whole unit .
Offline HP2
« Reply #2 on: January 15, 2015 - 05:22:22 PM »
Hurst also offers a rebuild service if you want to keep your original mechanism.
Offline CudamanTom
« Reply #3 on: January 15, 2015 - 05:34:29 PM »
I wouldn't replace it until cleaning and lubing it first as mentioned before.
Maybe a rebuild if everything looks wore out.
Then check your adjustments.
If none of the above works, replace it.
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
Offline Edison1970
« Reply #4 on: January 15, 2015 - 08:40:21 PM »
Most likely slop in the shift linkage from my experience.  They make a bushing kit  to tighten everything up.
Offline BadJoey
« Reply #5 on: January 16, 2015 - 03:59:17 AM »
By slop in the shift linkage are you talking about the body at the bottom of the shifter or the linkages to the trans ? Thanks
Offline Edison1970
« Reply #6 on: January 16, 2015 - 07:03:15 AM »
Both.  The kit I have has hardened steel inserts that would be inserted in the shifter levers on the trans.  Pull the shifter rods off one at a time and inspect the end of the rods and holes they go in.  I'll take a picture tonight to show you.
Offline 67vertman
  • Member since 9-23-2005
« Reply #7 on: January 16, 2015 - 04:21:18 PM »
Brewers sells a kit as well.  It a DYI job.
http://brewersperformance.com/products.asp?cat=132
Offline 4 speed fish
« Reply #8 on: January 16, 2015 - 04:56:25 PM »
The shifters are easy to rebuild.The full kit is about 100 bucks.I have done 3 of them.
Offline Sleepychallenger
« Reply #9 on: January 16, 2015 - 08:27:44 PM »
Will a missing shim cause issues?
Offline BadJoey
« Reply #10 on: January 17, 2015 - 06:32:19 AM »
Looking on the internet I found 3 choices .
1) A rebuild kit for $ 100.00
2) I can send it right to hurst and they will rebuild it for $250.00 plus any parts not in the kit .
3) My third choice is a whole new lower part for $ 300.00
I'm leaning towards choice 3 . I'll keep the old part . Is there any benifit to keeping the original part ? In the world of matching numbers do shifting parts count , either way I'll still have the original .
Offline Edison1970
« Reply #11 on: January 17, 2015 - 07:57:39 AM »
I would remove the shifter and rods first and inspect them.  It could be just the adjustment of the rods.  I would also check the clutch adjustment too.
Offline 73440
« Reply #12 on: January 28, 2015 - 09:32:26 PM »
Only trouble I have is it's a little work to get into reverse, as all are saying, that is probably adjustment needed.
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
« Reply #13 on: January 29, 2015 - 05:46:54 PM »
Reverse does take a bit more force to engage even when adjusted perfectly.
« Reply #14 on: January 29, 2015 - 07:19:18 PM »
I would go for option 4 , pull it out go through it & see how it works cleaned up & adjusted properly , no cost & if it needs parts you know what you need to replace !!
