Author Topic: Out of Body Shop Jail.......... Finally!  (Read 75963 times)
Offline Finoke
Re: Out of Body Shop Jail.......... Finally!
« Reply #120 on: March 21, 2015 - 10:50:55 AM »
Probably not. I think you will need to drive it around a bit and let them 'settle in'. Stock height for a Challenger had about 1-1.5" of tire up in the well. Not sure if a 'cuda was set up the same.
I thought the same thing. Drive with iT for awhile and see how it pans out  :2thumbs:
Offline Finoke
« Reply #121 on: March 21, 2015 - 10:54:47 AM »
As promised... A picture from behind, albeit still on the lift as a non runner. The tire to spring clearance is 3/4" on the drivers side and 1/4" on the passenger side. Each tire is equal to the qtr panel side of wheel well at 3/4".
Offline CudamanTom
« Reply #122 on: March 21, 2015 - 03:41:36 PM »
Lookin great Tom.  :2thumbs:
You could move the rear end to the right a tad if the tolerance on the right tire is an issue.
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
« Reply #123 on: March 21, 2015 - 04:15:11 PM »
How?
Offline Finoke
« Reply #124 on: March 21, 2015 - 04:44:58 PM »
Hi Tom,
I had slid the rear to make both tires even from the qtr panels that's why they are uneven at the springs. But yes I may slide it the other way a hair just to get mor than 1/4" at the springs on the passenger side.
Offline Finoke
« Reply #125 on: March 21, 2015 - 04:47:45 PM »
How?
It will slide until the perches are welded. Now Is the time to get it right  :2thumbs:
« Reply #126 on: March 21, 2015 - 09:12:43 PM »
Oh. OK. Didn't realize your perches were not yet welded to the axle.
Offline Finoke
« Reply #127 on: March 22, 2015 - 07:11:20 AM »
I know what's going to happen. As soon as I weld them, I will want to move them again. So I'm holding off till I'm definitely happy with everything.  :bigsmile:
« Reply #128 on: March 22, 2015 - 08:05:50 AM »
Remember to check/set your pinion angle as well before you weld.
Offline Finoke
« Reply #129 on: March 22, 2015 - 09:25:29 AM »
Will do, anybody have any tips? There is a million posts on various boards and a lot of the info differs. I did order a digital angle finder from summit. So hopefully that makes it easier.
Offline CudamanTom
« Reply #130 on: March 22, 2015 - 09:45:47 PM »
Hi Tom,
I figured as much to match the qtr panels and I understand why. Either way, you don't have a lot of room to play with. But then again, you don't need a lot of room to play with. Just enough is just right.  :2thumbs:
Your doin great so keep us posted.  :ylsuper:
Offline Finoke
« Reply #131 on: March 26, 2015 - 03:53:38 PM »
Okay, I  welded in the spring perches yesterday after setting the pinion angle. No issues. Today I put the  rear bumper on and installed the gas tank.
I must admit that it's looking pretty mean  :bigsmile:
Offline roadman5312
« Reply #132 on: March 26, 2015 - 04:08:41 PM »
NICE A$$    :cooldancing:
Offline Finoke
« Reply #133 on: March 31, 2015 - 10:59:17 AM »
Offline Finoke
« Reply #134 on: March 31, 2015 - 11:01:48 AM »
I got the front bumper on this morning. I still have to tweak the alignment a little, but good enough for now to move on.  :2thumbs:
