Sound deadener overkill
Author Topic: Sound deadener overkill  (Read 9717 times)
Offline Racer57
Re: Sound deadener overkill
« Reply #15 on: February 01, 2015 - 10:56:35 AM »
I don't care how hard it is to remove. I can't think of any reason to ever have to do it and whoever owns the car next I won't care about either because I'll be dead. (Don't plan on ever selling it)  :D
I have removed small areas where the seat will rest, holes for seatbelts etc and with a heat gun, it isn't too bad.
Offline cordodge
« Reply #16 on: February 02, 2015 - 01:21:19 PM »
here are some pics finally, sorry for the delay   bruce
1970 challenger 95% done
1969 roadrunner in progress
1969 D-100 13,000 mile truck
1969 L-700 tilt cab in progress
2007  Dodge Ram 4x4
2017 hyundia Santa fe ultimate
1977 VERY UNDERSTANDING WIFE !! 😇
Offline 3D
« Reply #17 on: February 02, 2015 - 02:52:04 PM »
Nicely done!
Offline cordodge
« Reply #18 on: February 02, 2015 - 03:38:19 PM »
Nicely done!
thx, It doesn't show but I also did behind all 4 interior panels and behind the rear pillars under the headliner to block off all the trunk noise.
it took a week to get my hands back to normal lol
bruce
2007  Dodge Ram 4x4
Offline Edison1970
« Reply #19 on: February 02, 2015 - 06:00:53 PM »
I really like what you did with the rally dash.  Did you do the white face gauges yourself?
Offline cordodge
« Reply #20 on: February 02, 2015 - 06:16:02 PM »
yeah did it myself, not really hard once everything is apart. also painted the needles. cant remember money wise but not expensive.
thx bruce
2007  Dodge Ram 4x4
Offline soundcontrol
« Reply #21 on: February 02, 2015 - 06:50:36 PM »
Looks great! What kind of material is Dynamat? Is it the heavy, kinda like a thick layer of undercoating? I have also seen material that more like dense foam.
/ Ken
topic=108917.new#new
Offline cordodge
« Reply #22 on: February 02, 2015 - 07:06:20 PM »
thx, yeah its heavy maybe 1/8 thick with butyl rubber type material, this stuff is real dense I used a heavy duty roller and some homemade tools to install it. its hard to explain the difference (night & day) makes the car sounds like lead! When you tap on it or shut the doors.
Bruce
2007  Dodge Ram 4x4
Offline 3D
« Reply #23 on: February 02, 2015 - 07:36:04 PM »
How many boxes did you use and what do you think it weighs?
Offline dave73chally
« Reply #24 on: February 02, 2015 - 07:52:57 PM »
:popcorn:
73 Challenger
Offline cordodge
« Reply #25 on: February 02, 2015 - 08:05:44 PM »
hey, used about 3-1/2 bulk packs it would be close to 50/55 lbs. the benefits out weight that in my opinion.  thx bruce
2007  Dodge Ram 4x4
Offline Edison1970
« Reply #26 on: February 02, 2015 - 08:56:21 PM »
Hey, just wondering if this product would do the same.  I work in the flooring industry and have access to a supplier that sell a product called Protecto Wrap.  We use it for anti fracture membrane and sound isolation under tile flooring.  I normally buy it by the roll which is 325 sf.  It has the butyl backing.  They also list an audio wrap that appears to be what we could use in our cars.
Audio Wrap™
AudioWrap is a thin butyl adhesive extruded on a flexible aluminum conveniently rolled up to be easily rolled out and cut for easy installation on car doors, floors, trunks and even license plates to eliminate vibration which causes noise. Audio Wraps butyl adhesive is scientifically formulated to absorb energy from thin sheet metal on doors and floorboards which cause unwanted road noise. When AudioWrap is installed the vehicle will feel instantly more solid, sturdier, and sound better. Audio Wrap is available for the average do-it-yourselfer and professional audio installer. AudioWrap is for any make or model of personal and commercial vehicles. Enjoy a quiet comfortable ride while listening to “Better Sound and Better Bass” brought to you by AudioWrap.
FEATURES & BENEFITS
Audio Vibration Control
Butyl Adhesive, Aluminum faced, Vibration control tape
Made in the USA
Quieter Ride
Maximum performance from your stereo
Sound deadening tape
Premium sound
APPLICATION Audio Wrap will form a positive and immediate adhesive bond to sheet metal, glass, and wood speaker boxes. SOUND DEADENING PROPERTIES The Acoustic loss factor measures sound dampening. The closer to 1, the less vibration. Realistically, any rating over .25 is very significant. Sheet metal alone can measure .001 at 200 Hz. Independent testing concluded that Audio Wrap measured an average of .2465 on 4 testing points, while the best competitor measured on average 30% lower at .1717 on the same test points.
« Reply #27 on: February 03, 2015 - 12:14:25 AM »
thx, yeah its heavy maybe 1/8 thick with butyl rubber type material, this stuff is real dense I used a heavy duty roller and some homemade tools to install it. Bruce
Heavy makes me wonder how heavy is it?
100 lbs or more?
« Reply #28 on: February 03, 2015 - 03:20:12 AM »
ThaTs cool, I'll just get an aluminum Hemi and save some weight on the engine! :bigsmile:
/ Ken
Offline cordodge
« Reply #29 on: February 03, 2015 - 08:26:20 AM »
haha yeah, that's one way to even the score. but I think if your not trying to shave 10ths off a time slip you would be very happy with it, 50lbs is probably like the added weight of an entire A/C system ? and im sure HP big block manifolds must weigh at least 30lbs.
bruce
2007  Dodge Ram 4x4
