Author Topic: engine harness 74 challenger  (Read 1017 times)
Offline Dgoode87
« on: January 18, 2015 - 03:16:06 PM »
ok I've looked at wiring diagrams looked through the threads and Im still lost maybe more so than when I started.
First of is the alternator I have the (black) (green) and (blue) hooked up but I have a (purple) plug and a (brown) wire that comes out of the same leg of harness and I have no clue...
on the other side close to the wiper motor I have a (grey), a (brown) and a (black/yellow) wire
and lastly closer to the fusable link  I have a three wire plug (black/yellow) (blue) and (yellow) I assume that's the seat belt thing
beside the three wire plug I have a dark grey wire aswell
thanks for any and all help
« Last Edit: January 18, 2015 - 03:23:07 PM by Dgoode87 »
Re: engine harness 74 challenger
« Reply #1 on: January 18, 2015 - 03:27:39 PM »
These are the alternator wires.
These 3 are coil wires
« Reply #2 on: January 18, 2015 - 03:39:40 PM »
Tach wire from port number 20 on the fire wall side bulkhead to the coil is a grey/black stripe.
You can get them from Classic Industries where I bought mine.
« Reply #3 on: January 18, 2015 - 04:54:57 PM »
The purple and brown wire coming out by your alt, one is for temp sensor and the other for the washer bottle motor. Purple for the temp if I remember right.
« Reply #4 on: January 18, 2015 - 05:15:49 PM »
The first picture the grey is oil pressure beside the dist on a small block , Blck / yel is - coil & brwn is + coil
Dodj has it right violet is temp , brown is washer pump , on the bottle .
Offline Dgoode87
« Reply #5 on: January 19, 2015 - 02:44:34 PM »
thanks guys Ill give it a shot next time I can steal 20 mins
