Author Topic: Oil Pan Designed to go around or miss Drag Link  (Read 5783 times)
Offline Mopar Thunder
« on: January 19, 2015 - 07:13:52 PM »
Who uses one and what manufacturer? I currently have one that allows a pass threw but I need to replace it.  I'm looking for one that is built so there is no pass thru.
Re: Oil Pan Designed to go around or miss Drag Link
« Reply #1 on: January 20, 2015 - 09:54:40 AM »
Milodon makes good pans that bypass the center link without a thru-hole.
« Reply #2 on: January 21, 2015 - 07:09:44 AM »
HP2, Thanks I'll check them out. I didn't look for Milodon yet. I really would like to get one w/o a thru hole.
« Reply #3 on: January 21, 2015 - 09:15:57 AM »
Milodon has a proven reputation with oil control. Their deep sump drag pans all miss the linkage. If your street driving, they make the pro-touring/road race pans that have extra capacity, fit in the stock location, and are no deeper than the K frame. Great for street driving ground clearance.
Offline Mpdlawdog
« Reply #4 on: January 21, 2015 - 12:58:04 PM »
anyone have a part number?? I can find it
« Reply #5 on: January 21, 2015 - 02:45:20 PM »
Road race big block 31580, road race small block 31590-340 and 31595-360.
Offline Mpdlawdog
« Reply #6 on: January 22, 2015 - 12:15:05 PM »
thank you!!  Its next on my list to get...
Offline vinb
« Reply #7 on: February 02, 2015 - 09:44:09 PM »
http://charliespans.com/
Build's a great pan....
Offline Denison636
« Reply #8 on: February 03, 2015 - 12:38:04 AM »
What motor you have. I got a milodon in my car and take a pic if you like. The only thing I am not happy with is how close one corner gets to the k-frame.
Its just a little 340 with a miss
« Reply #9 on: February 03, 2015 - 06:52:47 AM »
I have a Keith Black 340 X Block. Currently the car has a modified pan on it, not sure who's but it isn't in good shape.  So I was looking to change it out and possibly get one that doesn't have a pass thru in it.
Offline Denison636
« Reply #10 on: February 03, 2015 - 09:07:26 PM »
I can take a picture of pan on my 340 tomorrow if you like. If a 8 quart Milodon. Only went with this due to I plan on running the motor up stairs and heard that the 340 needed more oil to do this.
Car is on jack stands so no big deal to take some pictures.
« Reply #11 on: February 16, 2015 - 08:45:26 PM »
Denison 636,  if it's not a problem that would be great.  I would like to find one before the season hits just in case.  Thanks in advance
Offline Denison636
« Reply #12 on: February 21, 2015 - 04:15:55 PM »
This is the 8quart setup for e-body's small blocks
Offline Denison636
« Reply #13 on: February 21, 2015 - 04:17:26 PM »
And you can still drop the pan when the stearlinkage is off.
« Reply #14 on: February 21, 2015 - 05:19:58 PM »
Thanks, those pics are great.  Is that a custom or do you have a part # for it?
