Author Topic: 440 Timing  (Read 2031 times)
Offline iNTP
440 Timing
« on: January 20, 2015 - 03:54:22 PM »
440 wont start
1) Set piston 1 at TDC, set rotor right at spark 1 terminal on cap. ( Distributor's vacuum canister point to driver side)
Start the motor: it wont start, spraying gas out of carb, pop through carb
2) Turn the distributor clock-wise all the way (  Distributor's vacuum canister point to front)
Start the motor: it start.
Whats happened and whats wrong?
Offline Oldschool
  • Member Since 9-05-06
Re: 440 Timing
« Reply #1 on: January 20, 2015 - 03:59:31 PM »
Is the #1 cylinder at TDC on the compression stroke?  If it is at the top of the exhaust stroke, it will do what you are experiencing...   0.02
Ken  --  In Georgia
Offline roadman5312
Re: 440 Timing
« Reply #2 on: January 20, 2015 - 04:00:46 PM »
Offline iNTP
Re: 440 Timing
« Reply #3 on: January 20, 2015 - 04:39:34 PM »
440 wont start
1) ...
2) Turn the distributor clock-wise all the way...
When I say "all the way" it mean turn clockwise (about 90 degree) until vacuum canister hit the coolant hose. It doesn't mean turn distributor 180 degree.
Is it still symptoms of piston1 TDC when at exhaust stroke?
Offline dutch
Re: 440 Timing
« Reply #4 on: January 20, 2015 - 04:45:57 PM »
some more info..?
was anything done to it or suddenly no start?  wires on the cap in the right direction?
*** Bart ***
Re: 440 Timing
« Reply #5 on: January 20, 2015 - 04:59:00 PM »
Sounds to me like the damper is marked wrong or the outer ring has slipped , the engine wants more timing , bring it up to 3000 rpm advance the timing until advancing it doesn't increase RPM anymore then turn it CCW until the rpm just starts to drop & tighten the bolt & forget about it
Offline cudabob496
Re: 440 Timing
« Reply #6 on: January 20, 2015 - 06:46:23 PM »
wires crossed?
2011 Kawasaki Z1000
Offline iNTP
Re: 440 Timing
« Reply #7 on: January 20, 2015 - 08:04:30 PM »
Firing order is good.
What happen if use low octane, 87, into high compression 440?
Offline cudabob496
Re: 440 Timing
« Reply #8 on: January 20, 2015 - 08:37:25 PM »
get pinging under acceleration.
Won't prevent starting.
I'd trace each plug wire again.
2011 Kawasaki Z1000
Offline Chlngrcrzy
Re: 440 Timing
« Reply #9 on: January 20, 2015 - 08:44:31 PM »
Went through all this myself not too long ago. Pull your #1spark plug out. Take the distributor cap off, but get an idea where the #1 is located at. Remember the big block turns opposite of the small blocks. Stick your thumb over the spark plug hole and have someone crank over the engine. Let it turn over completely a couple times to verify you are on the compression stroke.
You can also buy the tape to lay on your dampener wheel to mark all the degrees, but that is only good if the dampener wheel isn't boogered up as CP suggested.
Verify spark plug wires are correct.
It should fire if you have gas, spark and on the correct stroke with correct order of wires.
Good luck
