Author Topic: 1970 Plymouth Barracuda  (Read 6365 times)
Offline swede-cuda
Re: 1970 Plymouth Barracuda
« Reply #15 on: January 23, 2015 - 06:24:06 PM »
 :clueless: 125$ ,hm, it must be a very special car.   :dunno:
Offline wantone
  • (O O {]{]{]||[}[}[} O O)
« Reply #16 on: January 26, 2015 - 11:30:36 AM »
Not seeing it either.
Want one?  Got one! ... finally
Offline 4 speed fish
« Reply #17 on: January 26, 2015 - 12:46:27 PM »
What would you want if it was a 4 speed?How did you come up with  125k?
Offline wantone
Offline javakm70cuda
« Reply #19 on: February 10, 2015 - 01:34:42 PM »
I don't see 125k but the NADA price range is a joke also. Just my thoughts
Offline EB3-GranCoupe
  • BP23 U0B
« Reply #20 on: February 15, 2015 - 02:01:54 PM »
Quote
Yes, the same cam used in a 440, windage tray, valve springs with dampers.... all 335hp engines were orange with HP stamped on it and came with Holley's...
cjm,
Carter/Holley was just a logistical supply issue, both were used on the 335hp and 330hp N-code e-bodies.  You are correct about the cam/springs being different.  the 335hp (383 magnum) used the same cam/springs as the 375hp (440 magnum); both were painted orange and only BS 'cuda's got those.  the 330hp used the same cam as the 2bbl 383 L-code, but had a four barrel intake and was painted turquoise; these are installed in the BH & BP Barracuda's.
Offline cjm
  • 70 Cuda - In Progress.....
« Reply #21 on: February 17, 2015 - 10:47:45 AM »
cjm,
I could be wrong, but I think in 69 it was a Carter & in 70 it was a Holley...
