Author Topic: Big block HP manifold down pipes  (Read 1043 times)
Offline Sly_drums
« on: January 21, 2015 - 05:44:57 AM »
Hello, I'm searching for a pair of used or new big block stock down pipes.
My 383 currently has Hooker headers and a 2,5 inch dual exhaust linked to it, but I want to go back to stock HP manifolds (no more clearance issues and I like the stock looking of them...).
I just bought a pair of them but now I'll also need a pair of those down pipes/flange pipes to connect the manifolds to the exhaust pipes.
I don't need the exact matching parts but only the parts that connect to the manifold and go down. I know it will need soldering here and there with additional tubes to match the current exhaust.
Do you know where I can find such parts ? Used or brand new ?
Thanks  :jumping:
Offline anlauto
Re: Big block HP manifold down pipes
« Reply #1 on: January 21, 2015 - 07:15:44 AM »
Try Accurate LTD....you might have to buy a set of headpipes. Actually I know TTI sells just what you need, but I'm not sure if they have them in a "stock" size.....worth looking into. :2cents:
Offline Sly_drums
« Reply #2 on: January 21, 2015 - 11:41:37 AM »
Thanks Anlauto, I just sent a mail to Accurate LTD  :ylsuper:
TTI don't seem to have the "stock" sizes.
Offline Gumby
« Reply #3 on: February 10, 2015 - 07:13:16 PM »
See my reply to your other post. Check out TTI. Hope this helps.
{oo/-------\oo} In '69 I was twenty-one and I called the road my own. I don't know when that road turned into the road I'm on. Jackson Browne
