Author Topic: E Body 3" Spring Relocation Kit  (Read 9822 times)
Offline RCCDrew
Re: E Body 3" Spring Relocation Kit
« Reply #15 on: February 24, 2015 - 02:50:36 AM »
Very cool setup. The leaf springs aren't curved. The mounts are set up so that the springs are in at an angle. You will also have to deal with the rear valence humps when relocating the springs.
Offline GreenFish
« Reply #16 on: February 24, 2015 - 07:24:29 AM »
sweet Jesus that's a lot of tire!!
« Reply #17 on: February 24, 2015 - 09:28:47 AM »
The leafs aren't curved, but are straight. Rather the mounts are are splayed with the front mounting points narrower than the rear mounting points. It is done deliberately for handling improvements. 71-74 B bodies and 76-80 F bodies also have splayed mounting arrangements. It minimizes rear steer characteristics compared to a parallel leaf arrangement.
Tires still look too wide to fit inside the fender lip. Maybe its just camera angle.
Offline 3D
« Reply #18 on: February 26, 2015 - 11:33:33 AM »
I had time last night to hang a couple of 4" x 12" plates from the spring mounts, I then put a straight edge across from driver side to passenger side. yes indeed they are defiantly angled outwards.
Offline jhaag
« Reply #19 on: February 26, 2015 - 07:58:36 PM »
to answer your original question, when I bought my car it had been drag raced most of it's life. it had a round bar (probably 1 1/2") welded between the frame rails with fabricated brackets mounting the shackles just as the oem. problem with this method was it raised the back of the car several inches. must have worked for them? I have removed this setup and gone back to stock.
love 70 Challengers
Offline 3D
« Reply #20 on: March 21, 2015 - 11:20:33 PM »
Finally, got the front all welded in and the rear brackets fabbed and tacked in place, What a job.
It actually moved my leafs in 4" per side.
Now I can get on to the tubs!
Offline DKCHAL
« Reply #21 on: April 05, 2015 - 02:33:43 PM »
Hey
I'm thinking on doing this spring relocation on my Challenger too
do you have any pics of the rear mounts.
Offline 3D
« Reply #22 on: May 31, 2015 - 08:34:16 PM »
Hey
I have lots of pictures, but basically what I did was cut out the rear frame sections from one of my parts cars (had one with solid rear frame rails). the factory rear frame sections angle inwards on each side, so what I did was cut and section the left frame and install it on the right side and vise/versa for the opposite side. This way the springs, hangers & mounts all install just as factory. I think you can buy 32" sections of rear frame rail (http://www.ebay.com/itm/70-71-72-73-74-Cuda-Challenger-Rear-Frame-Rail-Pair-MADE-IN-USA-/200584012647?hash=item2eb3bd2367). You will have to modify the trunk pan to suit.
Hope the pictures help. This was the best way I could think of doing it and still look decent/factory. originally I was going to mount a piece of 3" x 2" angle iron at the back frame rail to frame rail but had interference with the gas tank.
« Last Edit: June 06, 2015 - 11:24:26 AM by da4ad »
Offline 3D
« Reply #23 on: June 01, 2015 - 12:07:02 AM »
Here's a picture of the tire mocked up with plenty of room, I now have 16-1/2" of room without rolling the fender lip! Also a picture of how I modified the frame rail.
« Last Edit: June 01, 2015 - 12:10:28 AM by da4ad »
Offline DKCHAL
« Reply #24 on: June 03, 2015 - 02:40:58 PM »
:ylsuper:
Offline 3D
« Reply #25 on: June 04, 2015 - 10:44:01 PM »
Finished the trunk pan tonight.
Offline 3D
« Reply #26 on: September 19, 2016 - 09:30:15 PM »
Just thought I would update this, been busy and haven't been on in a while.
This is where I'm at now.
« Last Edit: September 19, 2016 - 09:36:11 PM by 3D »
