Author Topic: 1970 440 vapor seperator  (Read 948 times)
Offline Jack440
« on: January 21, 2015 - 08:12:27 PM »
I am only posting this question since I could not find the answer in previous vapor separator posts.  Is it the normal function of the separator on a 70 440 with mechanical fuel pump to circulate liquid fuel back to the tank on a continuous basis, not just a few vapors now and again?   Should there be a constant flow of fuel back to the tank?
Offline anlauto
Re: 1970 440 vapor seperator
« Reply #1 on: January 21, 2015 - 08:18:52 PM »
Just for vapours :2cents:
Offline mopar jack
« Reply #2 on: January 21, 2015 - 08:24:28 PM »
The filter vapor seperator has a 1/8 restriction that allows a small amount of fuel to continually flow to the tank.
Offline 1 Wild R/T
« Reply #3 on: January 22, 2015 - 11:07:07 PM »
Sort of correct... Unfortunately that 1/8 restriction is what the reproduction separators have, original separators have a .060 restriction, the return exits the bottom of the separator but the tube extends nearly to the top of the separator, vapors rise so they pass through the return along with a  minimal steady flow of fuel..... Fuel going to the carbs is fed out the top of the separator but that tube extends past the middle of the separator...
