Author Topic: Pistol Grip Shifter / Tremec tranny. Bolt removal  (Read 794 times)
Offline Racer57
« on: January 26, 2015 - 02:42:23 PM »
I'm ready to install new carpet and need to remove the shifter. The shop that installed the tranny apparently used red locktite and over tightened the allen heads. I used a quality allen and they both rounded out.  :swear: So now I have to drill the heads. :banghead:  Any one have an idea of how hard of metal these are ?
Offline anlauto
Re: Pistol Grip Shifter / Tremec tranny. Bolt removal
« Reply #1 on: January 26, 2015 - 02:47:42 PM »
If they stripped that easy, I would say they are not that hard. Get yourself some good drill bits and start small. :2cents:
Offline roadman5312
« Reply #2 on: January 26, 2015 - 03:37:04 PM »
A little heat from a propane torch will soften the locktite.
Offline bdalehemi
  • Ramblin Wreck!!!!
« Reply #3 on: January 31, 2015 - 11:23:33 PM »
I must agree that heat will turn that loctite into lubricant just about
Offline HP_Cuda
  • Mopar or No Car!
« Reply #4 on: February 01, 2015 - 01:23:17 PM »
Apply heat and use an easy out = done.
Do not repeat the use of these bolts!!!
