Author Topic: Take me to alternator school  (Read 1359 times)
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« on: January 27, 2015 - 10:37:20 AM »
So I ordered my full Msd setup, and I have a new engine wiring harness here ready to go, so I figure that as long as I'm re-wiring the entire engine bay and modifying the harness, this would be the time to upgrade the alternator.  I know I want the Tuff Stuff brand, but I have questions.
1. Power, how much do I need?  90? 145? Just adding a stereo and electric fans, not much more in terms of additional draw.
2. 1 wire or 3, what's the difference, and what's the point?
3.  Regulator?  I see some have an internal regulator and some don't, do I need one?
Thanks guys,
Wiring is like voodoo to me so the less modifying I can get by with, the better! Haha
Scott in Omaha
2015 crew cab Hemi ram SOLD
2019 Ram Laramie
2016 Tahoe LTZ SOLD
1976 Ramcharger 383 4spd SOLD
2016 Audi
24 mopars past and 2 present
Re: Take me to alternator school
« Reply #1 on: January 27, 2015 - 08:36:01 PM »
Fans draw a lot of current so I would look at 125 amp or more .
 I prefer 3 wire , why replace the alt for a simple $10 voltage reg that is external ? yes you always need a reg either internal or external .
 For anything over 60 amps I would recommend installing a 10 ga bypass wire from the alt output to the bat terminal on the start relay .
 While you are at it install headlight relays so you can see where you are going !
« Reply #2 on: January 27, 2015 - 08:50:56 PM »
More output, more electronic toys.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #3 on: January 28, 2015 - 04:21:06 PM »
I did a 60A alternator recently and still used the bypass wire.
Why you ask? Well because the last fool who hooked up the regulator didn't do a good job of grounding it and caused over voltage problems. I put my hands on the alternator guage wires and they were getting plenty warm. Now most everything flows through the bypass and I don't much care about the low readings on the guages instead of a fire occuring.
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #4 on: January 28, 2015 - 07:12:08 PM »
Thanks for all the input guys!! Alternator is on the way, along with a headlight bypass kit from Rob.  :bananasmi
Scott in Omaha
2019 Ram Laramie
2016 Tahoe LTZ SOLD
2016 Audi
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #5 on: January 30, 2015 - 03:44:17 PM »
Oooooooo yeah!
Scott in Omaha
2019 Ram Laramie
2016 Tahoe LTZ SOLD
2016 Audi
« Reply #6 on: January 30, 2015 - 04:20:56 PM »
I think I've pretty much decided that I don't want to mess with a stock style alternator.  The old style...even the higher amp ones...just don't put out anything at idle.  I'm going to try to adapt a new compact denso to some aluminum brackets designed for the old alternators.  I want to try and run an electric fan and I don't want the headlights to dim at stop lights.  I also have a convertible top that will draw a lot of juice.  I already have a headlight relay kit and plan on running a jumper wire from the alt directly to the starter relay.
AR Engineering makes steel alternator brackets designed for the new smaller denso alternators.  Unfortunately, I want to run aluminum brackets up front.
http://arengineering.com/products/sb-with-8172-race-powermaster-alternator/
