Author Topic: Black Oxide / Zinc-phosphate for nuts & bolts  (Read 1660 times)
Offline GCC
« on: January 27, 2015 - 11:53:09 AM »
I have lots of hardware for suspension & brackets that needs to be plated (black oxide, zinc-phosphate, etc).  The parts don't need to be show-quality, but just have some level of protection that is not a paint coating.  What is a good DIY at-home solution for this?  Any suggestions for the Caswell and/or Eastwood kits?  Thanks!
Offline anlauto
Re: Black Oxide / Zinc-phosphate for nuts & bolts
« Reply #1 on: January 27, 2015 - 12:22:28 PM »
Eastwood has a metal blackening kit....I could never get good results with it, and it requires a clear coat  :sadwavey:
Offline 1 Wild R/T
« Reply #2 on: January 28, 2015 - 12:49:52 AM »
I tried the Caswell stuff years ago... Same result...  Now I gather all the stuff from my project & see if any friends need the same plating done it a similar time frame....
Offline cuda lover
« Reply #3 on: February 17, 2015 - 03:07:20 PM »
I did this hood latch by soaking away the rust with phosphoric acid and if you leave it on it creates a dark grey coating, they say it protects from rust for up to a year.
on this hood latch I did only a 1/2 strength wash and then coated it with clear coat.
CUDA Lover
Offline crash340
« Reply #4 on: February 17, 2015 - 03:20:37 PM »
Try Brownells, they have small kits for DIY gun repairs, Phosphating is an easy process done at home,, very easy, temp is just short of boiling, one chemical mised with water, sit the items in it until they stop fizzing and done, spray with oil, good to go.
Greg
73 Cuda
Brisbane, Australia
Offline brotow
  • There really is a Challenger in the backround
« Reply #5 on: February 17, 2015 - 06:33:32 PM »
I powder coat my hardware. You can get a powder coating kit for under $100, hook it to a compressor and you will need a way of baking them to "set" the powder coat. My mothers old wall oven is perfect, I can fit 15"rims. Must be electric, no flame. They would also have to be blasted to clean metal first.
Here's a original master cylinder I powder coated, including the rod.
70 Chall. vert.(in process) - 73 Amx -74 Javelin- 87 Wrangler-02 Sebring conv. 2005 Crossfire srt roadster
