Author Topic: Adjusting ride height  (Read 1547 times)
Offline blown motor
« on: January 28, 2015 - 06:09:28 PM »
On the front end there is an adjusting bolt between the two halves of the lower control arm. Is that the bolt that is used to adjust the ride height? Do I turn it in or out to raise the front end?
Offline anlauto
Re: Adjusting ride height
« Reply #1 on: January 28, 2015 - 06:22:37 PM »
In for UP, out for DOWN.
You should loosen the large nut on front of the control arm as well :2cents:
Offline blown motor
« Reply #2 on: January 28, 2015 - 06:54:35 PM »
Thanks Alan.
« Reply #3 on: January 28, 2015 - 07:06:02 PM »
I recommend tightening it back up when you are done.  :biggrin:
Offline blown motor
« Reply #4 on: January 28, 2015 - 07:11:12 PM »
Genius just drips from you Scott.  :rofl:
Offline CUDA JAS
  • vroooooom!
« Reply #5 on: January 28, 2015 - 08:23:15 PM »
and please jack up the car and properly support it with no weight on the front suspension prior to adjusting that bolt.
There have been some reports of the bolt or insert striping and the car dropping.
also make sure you torque the large control arm nut with the car at ride height.
Jason
74 'cuda 360/727
Just call me a gearhead!
« Reply #6 on: January 28, 2015 - 10:12:25 PM »
And you really need to drive it around the block or whatever for it to settle in to the new setting. Just bouncing the front end doesn't get the job doe. :2cents:
It's a gift.  :icon16:
