Author Topic: 70 chall rear frame rail holes  (Read 2137 times)
Offline brotow
  • There really is a Challenger in the backround
« on: February 01, 2015 - 12:50:44 PM »
Does anyone know what goes on the two 7/16 holes on the bottom of the rear frame rails about 1 1/2 to 2 feet from the rear shackles, about even with the rear wheel wells, before the shock mount cross member?
70 Chall. vert.(in process) - 73 Amx -74 Javelin- 87 Wrangler-02 Sebring conv. 2005 Crossfire srt roadster
Offline shawge
  • Zoiks!!
Re: 70 chall rear frame rail holes
« Reply #1 on: February 01, 2015 - 01:09:36 PM »
Probably the transport tie downs.  I think they were typically removed by the dealer.
- Jerry
Offline shawge
  • Zoiks!!
« Reply #2 on: February 01, 2015 - 01:14:56 PM »
Or maybe the axle bump stops?
- Jerry
Offline HP_Cuda
  • Mopar or No Car!
« Reply #3 on: February 01, 2015 - 01:15:14 PM »
Offline brotow
« Reply #4 on: February 01, 2015 - 01:30:49 PM »
Yep, the transport tie downs. I'll be re-installing them. Thanks, and thank you for the picture.
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #5 on: February 01, 2015 - 05:37:25 PM »
They don't hurt anything and are good if you are ever going to transport your car.
Offline AAR6BBL
« Reply #6 on: February 18, 2015 - 02:02:09 PM »
So that is what the hell those things are! I thought at first that they were tow brackets :screwy:
They looked like they were factory from the markings, but I had no idea what they were for.
Now it makes sense
This forum is awesome :thumbsup:
Greg
"There's no such thing as putting a '70 AAR 'Cuda exactly where you want it. The 'Cuda isn't interested in such things, for they require finesse. Finesse asked the 'Cuda out to dinner once, but the 'Cuda stood it up to go drink beer under an overpass with her hot little sister. As far as this car is concerned, finesse can go stuff itself."
Offline brotow
« Reply #7 on: February 18, 2015 - 05:32:32 PM »
The picture shows how the brackets are installed, however mine seem to fit better with the left and right reversed as the picture.  Is there a correct way the higher edge should face? Inside or outside?
« Reply #8 on: February 19, 2015 - 10:14:11 AM »
The picture is correct.  The "open" edge goes to the outside...
Offline anlauto
« Reply #9 on: February 19, 2015 - 10:32:37 AM »
Odd...The above picture looks a lot like a 71 Cuda I restored years ago....but even I don't have pictures of it :clueless:
