Author Topic: How to Remove a solid pulley for Saginaw Power Steering Pump  (Read 3211 times)
Offline FCC
  • 1973 Dodge Challenger 340
« on: February 01, 2015 - 04:37:20 PM »
I have a Saginaw power steering pump with solid pulley.  I can clamp the pulley down on the vise to remove it but it will destroy the pulley.  What is the best method to remove and install the pulley without damaging it???  Would it be best to replace it with one having holes?  That way I can put a screwdriver through it to stop it from spinning.  I'd prefer to keep the original pulley though!  Any help would be greatly appreciated!  Thanks.
Offline 67vertman
  • Member since 9-23-2005
Re: How to Remove a solid pulley for Saginaw Power Steering Pump
« Reply #1 on: February 01, 2015 - 09:59:50 PM »
I used a little heat on mine.....it slid right off.
Offline dougs bs23
« Reply #2 on: February 01, 2015 - 10:28:23 PM »
Offline FCC
« Reply #3 on: February 02, 2015 - 04:34:23 AM »
Thanks for your replies.  Sorry for the confusion.  I have the puller set so let me clarify my question...
The pulley spins when I try to remove the retaining nut before I can use the pulley remover.  What is the best method to hold the pulley still while the nut is being removed (or installed) so the pulley doesn't spin?  Thanks.
Offline mopar jack
« Reply #4 on: February 02, 2015 - 12:08:25 PM »
I would try a good impact gun but not an air ratchet.
Offline 1 Wild R/T
« Reply #5 on: February 02, 2015 - 12:20:06 PM »
Yup, Impact, if it has a nut you won't need a puller...
Offline FCC
« Reply #6 on: February 09, 2015 - 07:02:37 AM »
Thanks All! Using an impact gun worked!  :)
FYI, I still had to use a puller to remove the pulley once the nut was off.
