Author Topic: Big block HP manifolds : head pipes / down pipes diameter question  (Read 3263 times)
Offline Sly_drums
« on: February 02, 2015 - 03:27:50 AM »
Hi guys, I need your help on this one.  :clueless:
My 383 Challenger has Hooker long tubes headers and a dual 2.5 inch exhaust.
I'll get rid of the headers soon since :
-   I want to go back to a more stock looking motor
-   I have clearance problem on the left side with one header rubbing on a tie rod
I just bought a pair of stock HP manifolds that I'm going to install on the car.
Problem is that I need to connect the manifolds to my actual dual exhaust which has been made for headers. Stock head pipes are 2.25 inch wide and I don't want to "reduce" my exhaust at this point.
I got in contact with ACCURATE LTD. They can build "special" 2.5 inch head pipes for me, as it's the actual diameter of the dual exhaust pipe. Anyway I don't know how it will flow with the stock manifolds ? Inside diameter is narrower than headers I think.
What do you adivse me to do ? Order special 2.5 inch headpipes or standard 2.25 headpipes ?
Thanks a lot for your input.
« Last Edit: February 02, 2015 - 03:29:28 AM by Sly_drums »
Re: Big block HP manifolds : head pipes / down pipes diameter question
« Reply #1 on: February 02, 2015 - 04:02:20 PM »
Standard head pipes.  Make sure the manifolds are for 1970 as 1 side is clocked different than the 68/69     The hp difference you might be worried about is very marginal and on your street car, you will see no difference. Not worth the extra money
Offline 73restomod
« Reply #2 on: February 03, 2015 - 02:33:41 PM »
You could port the exhaust manifolds, enlarge the opening to help with anti-reversion, radius/blend the entry in to the main body, and smooth out and enlarge the collector a bit. If you want to go really nuts you could than have it extrude honed. All of which could net an extra 7-12 hp, nowhere near what a set of headers will give, but If one of your main hang-ups is clearance why not go for a set of Tri-Y's?
Offline anlauto
« Reply #3 on: February 03, 2015 - 02:43:12 PM »
Just get new exhaust head pipes :2cents:
Offline ToxicWolf
« Reply #4 on: February 03, 2015 - 02:59:18 PM »
 :iagree:  Even the original hemi pipes were 2 1/4.
Offline Gumby
« Reply #5 on: February 10, 2015 - 07:11:20 PM »
TTI sells down pipes that fit the HP manifolds. They are relatively cheap. I can't remember the pipe diameter,
Maybe they can build it to your specs? They need the casting numbers of your manifolds for appication.
There is a section on their website covering this.
{oo/-------\oo} In '69 I was twenty-one and I called the road my own. I don't know when that road turned into the road I'm on. Jackson Browne
Offline Sly_drums
« Reply #6 on: February 14, 2015 - 04:37:13 AM »
Thanks Gumby, problem is that the TTI are aluminized, which is a problem if I need to solder then ? Or is it just aluminized paint over steel pipes ? If yes, then TTI will fit !
« Reply #7 on: February 14, 2015 - 11:40:12 AM »
Nope. 2.5" until resonator output then 2.25" after was how OEM were.
Offline Gumby
« Reply #8 on: February 14, 2015 - 09:03:19 PM »
You can always just use the band style clamps. Something ike this, they come in all styles and shapes and sizes- even from one pipe size to another, stainless, whatever you want
They don't require welding, and you can easily dis-assemble your exhaust, if need be.
http://www.summitracing.com/search/part-type/exhaust-clamps/clamp-style/band-clamp-lap-joint
They been in use for years ad years and years, and flat out work. NO welding.
I really never understood why people welded stuff together when 1) They didn't have to and 2) dis-assemby is SO much easier and 3) the time it takes for someone to weld - $ per hour - these things are probably cheaper in the long run
« Last Edit: February 14, 2015 - 09:23:31 PM by Gumby »
Offline Sly_drums
« Reply #9 on: February 16, 2015 - 01:21:17 AM »
Thanks Gumby, looks like the TTI headpipes are what I need, and they sell 2.5 inch diameter.
