Strange and QA1 appear to be very similar twin tube, aluminum body designs. The Ridetech says is a monotube design. Monotube will provide more precision over the control over a twin tube. Monotubes also have larger oil reserves in them to avoid foaming and overheating, should you drive the car for extended periods of time. However, as you see, twin tubes are easier to make which results in lower prices and because the are a tube within a tube, they can sustain road damage and still remain functional. Probably not a big deal in a car, but it could be in a truck.
I doubt any of them will help much with traction issues with 15" Firestone street tires. With a UTQG tread rating of 500, these tires are rock hard for mileage, not traction. All the shocks are going to do for you is delay or speed up the springs reaction. I doubt you could delay it enough to prevent blowing off the tires at a 500 tread wear.
If you are the type that doesn't mind keeping records of adjustments and changes, adjustable shocks may be for you. However, it is possible to head the wrong direction with them if you don't have time for adjustments and testing and adjustments and testing. If you prefer to worry less about the adjustments and just want to drive, then the fixed valving Hotchkis/Fox shocks are probably the best fixed valve, bolt it on, and go shock out there.
