Author Topic: The exhaust jack  (Read 3128 times)
Offline roadman5312
The exhaust jack
« on: February 03, 2015 - 03:41:28 PM »
Hmmmmmm, not sure about this one. Whatcha all think   :feedback:   http://speedsociety.com/exhaust-jack-need-to-change-tire-quick/
Offline ToxicWolf
Re: The exhaust jack
« Reply #1 on: February 03, 2015 - 04:11:02 PM »
Being experienced in changing a tire  :bigsmile: I think this is great.  Unless, of course, you have an electric car.   :roflsmiley:
Offline roadman5312
« Reply #2 on: February 03, 2015 - 04:29:50 PM »
                     Still braggin about that tire change   :smilielol: :smilielol:
Offline cudabob496
« Reply #3 on: February 03, 2015 - 07:26:24 PM »
accident waiting to happen
company will then be sued out of existence
2011 Kawasaki Z1000
Offline OUTLAW
  • MASTER OF ALL THINGS MOPAR
  • I didn't say you can't RACE--I said you can't WIN
    • MOPAR-MADNESS  WEB/FORUM
« Reply #4 on: February 03, 2015 - 07:32:39 PM »
what happens when the gasses from the exhaust deteriorates the rubber bladder and you want to use it a year later
Offline Denison636
« Reply #5 on: February 03, 2015 - 08:03:04 PM »
I use to use air bags to raise a corner of a overhead cranes to change wheels. Most I picked up with an air bag is only 150,000 lbs at 90psi of air. I always used oak to crib up after I got it up but like the ideal for cars. I know it will scare people until they are use to it.
Its just a little 340 with a miss
Offline OUTLAW
« Reply #6 on: February 03, 2015 - 09:58:01 PM »
the only  problem I see is the gases and acid in exhaust deteriorating the rubber over time. An example is: when I had my Harley I bought a emergency tire repair kit that had a hose to inflate the tire by removing a spark plug and connecting this hose between the valve core and 1 cylinder. Then using just the starter to pump air from the cylinder into the tire. Worked great, would pump up the tire in just a couple of minutes. 6 months later when I had another flat , the inside of the tire looked like it was made out of snot and old condoms.
Offline Denison636
« Reply #7 on: February 03, 2015 - 11:33:53 PM »
Where did you get that kit Outlaw. Sounds like a good Christmas present for my old man. He is a Harley rider and I hate being a good boy and picking him up in my pickup.
Offline OUTLAW
« Reply #8 on: February 04, 2015 - 02:47:42 AM »
 I got it from J.C.Whitney, don't know if they still have them. I was glad I had it as I was way out in the middle of nowhere and caught a piece of fence wire. Had a tire plug in the kit to fix it with but no way to pump it up. That hose was worth it's weight in gold that night...LOL
Offline aris_unlimited
  • Project in full swing
« Reply #9 on: February 05, 2015 - 12:21:01 AM »
Random thought, I wonder if that airbag would work with a dual exhaust that has a crossover pipe...
Cuda is gone :(
74 satellite, daily driver/project now
Offline dakota
« Reply #10 on: February 07, 2015 - 08:52:24 PM »
Aris - I think a crossover would be a problem.   The exhaust would follow the path of least resistance, which would be out the open tailpipe.
