Author Topic: Help, 1970 'Cuda - Need a Measurment  (Read 1805 times)
Offline 3D
« on: February 08, 2015 - 09:18:38 PM »
Well had a productive weekend, Got my driver side A pillar and roof bracing welded on.
I need to confirm a measurement as shown in the pictures.
Can somebody measure this point from the drivers door to the pass door over the windshield??
Thanks in Advance.
Offline 3D
Re: Help, 1970 'Cuda - Need a Measurment
« Reply #1 on: February 09, 2015 - 03:26:19 PM »
I'M looking to confirm the 64-3/4" measurement.
Offline calicuda70
  • 2 evil 70's and 1 BAD 11
« Reply #2 on: February 09, 2015 - 03:32:19 PM »
ill measure this when i get home my car is in the same state right now. ill need a measure and picture from you in return lol if you dont mind rear window roof ill get to you in a couple of hours
james
70 'Cuda 5.7 Hemi protouring resto
70 Challenger 360
11 Challenger SRT8 392
Offline 3D
« Reply #3 on: February 09, 2015 - 05:32:42 PM »
james
Not a problem, thanks
Offline 3D
« Reply #4 on: February 13, 2015 - 06:32:21 PM »
Wow, i cant be the only one with a '70 Cuda?
I know it not an accurate measurement, but last time i had the front end togeather my front fenders were about 3/4" to wide at this point.  Im using goodmark fenders and an original hood. Im thinking the tops of the aftermarket fenders are slightly wider than oem.
Can someone get me a quick measurment?
« Last Edit: February 13, 2015 - 06:38:35 PM by da4ad »
Offline calicuda70
« Reply #5 on: February 14, 2015 - 12:09:10 AM »
Dude I apologies I did it but it didn't post I got 64 1/8th so ur probably dead on
70 Challenger 360
Offline WildJones
« Reply #6 on: February 14, 2015 - 03:02:11 AM »
I can double check this tomorrow morning.
95682
1970 Cuda
Offline calicuda70
« Reply #7 on: February 14, 2015 - 08:20:34 AM »
Also remember the door can adjust inwards as well so it will be different between each car
70 Challenger 360
Offline 3D
« Reply #8 on: February 14, 2015 - 09:27:04 AM »
Thanks a lot,  :2thumbs:, you're actually narrower than mine.
I'm trying to set all the door gaps around 3/16" +-.
Do you also have about a 3/4 gap at the bottom of the door to the rocker? In repairing A pillar damage on the drivers side. My passengers door has the same 3/4" gap so that's what I went by.
Cheers
« Last Edit: February 14, 2015 - 02:11:37 PM by da4ad »
Offline calicuda70
« Reply #9 on: February 14, 2015 - 04:35:00 PM »
My lower gap is about 3/8th wide.
70 Challenger 360
Offline WildJones
« Reply #10 on: February 15, 2015 - 04:02:09 PM »
Just to confirm, mine is also 64 and 3/4". Maybe a hair wider, but I was trying to measure it solo So might be a bit off.
95682
1970 Cuda
