Author Topic: 73 Challenger restomod  (Read 78698 times)
Offline redo1973
Re: 73 Challenger restomod
« Reply #135 on: February 19, 2016 - 09:16:22 PM »
Looking good.  I've seen some of those gold or copper ones and they look cool.  I did a detail grey from Eastwood to simulate steel but my brake calipers are silver and steering is black.  I've installed the spindles for temporary fitting of other work I need to do.  I can take some pictures for you if you'd like.
Offline soundcontrol
« Reply #136 on: February 20, 2016 - 07:32:12 AM »
So I got my qa1 struts and they are a metallic gold. Much different than the shade of gold I painted my lca's so now it looks just plain stupid.  :banghead:Might try to find a different shade but if I can't, should I go silver or black? What do
you think?
I got the same color LCAs, a bit darker maybe, painted my struts gray metal first, didn't look good so I changed them to black, that always work. But since yours are probably plated, you might not wanna paint them. Sure it looks bad? Post a picture. Maybe add a darker coat to the LCA's?
Now my wife asks what I'm doing on the computer, I tell her, and she just shakes her head and says "big manproblems!"  :grinno:
/ Ken
topic=108917.new#new
« Reply #137 on: February 20, 2016 - 08:20:12 AM »
you think?
Here is  mine for reference? I used VHT engine paint if that helps?
« Last Edit: February 20, 2016 - 08:22:08 AM by brads70 »
Offline dave73chally
« Reply #138 on: February 21, 2016 - 05:34:04 PM »
Got a lot done this weekend:
 K frame assembled:
Steering column pulled to install new bearing and rebuild coupler:
My steering colum wiring looks like it was hacked in the past, what is the yellow wire for?
Started bodywork on the engine bay:
And this weekends casualty...don't buy a vise from harbor freight. Broke when pressing out the steering shaft pin into a socket to slide on a new bearing...
« Last Edit: February 21, 2016 - 06:43:13 PM by dave73chally »
73 Challenger
« Reply #139 on: February 21, 2016 - 06:24:54 PM »
Nice, been busy! I don't have that yellow wire on my column.
/ Ken
« Reply #140 on: February 24, 2016 - 09:24:41 PM »
Did the er16 bearing upgrade on my steering shaft. That lower pin in the shaft is a bear to get out. The bearing itself needed some grinding and some persuasion with a hammer but it fits really well now. Great upgrade over stock and cheap!
73 Challenger
Offline 70chall440
« Reply #141 on: February 24, 2016 - 10:43:17 PM »
Very nice, coming along well.
Current Mopar
Past Mopars
Offline diyhemi.com
  • Formerly Yellowfin
    • DIYHEMI.COM
« Reply #142 on: February 25, 2016 - 07:16:22 AM »
Great work!
Also, where does one get that bearing? Do you have a part number?
1970 Barracuda Gran Coupe, gen III project (Cone Killing Cuda)
Offline anlauto
« Reply #143 on: February 25, 2016 - 07:25:12 AM »
Yellow wire is part of the A01 light package. It powers the timer delay light that shines on the ignition switch. :2cents:
« Reply #144 on: February 25, 2016 - 08:42:03 AM »
Great work!
I bought it from this seller, fast shipping and best price I could find:
http://www.ebay.com/itm/121710889905?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
73 Challenger
« Reply #145 on: February 25, 2016 - 08:44:15 AM »
Great to know, thank you! Any idea what may have been spliced into it? When is that wire hot? I didn't cut the orange wire, it was like that...
73 Challenger
Offline anlauto
« Reply #146 on: February 25, 2016 - 08:48:41 AM »
It was probably plugged into the A01 dash harness, or if your car doesn't have that then someone may have connected it to the orange wire dash lights. If it has the proper timer harness then it only has power for a limited time. :2cents:
« Reply #147 on: February 29, 2016 - 09:10:29 AM »
Did some more bodywork on the engine bay. Should be able to shoot some primer within the next few weekends. I don't envy anyone that does bodywork for a living...
73 Challenger
« Reply #148 on: March 16, 2016 - 09:46:12 AM »
Welded in the us car tool fender braces and rad brace. Getting better at the welding...
Here's sneak peak of my new motor, should be picking it up in the next few weeks:
73 Challenger
« Reply #149 on: March 16, 2016 - 10:23:11 AM »
Nice! I'm about to do mine, but work is killing me right now, no time. Did you treat the insides with anything? I thought I sandblast and prime the car first, might be hard to get to after the welding.
/ Ken
