Author Topic: Cuda Guy Project Update  (Read 7231 times)
Offline The Cuda Guy
  • Support Our Troops
  • Pearl Harbor, HI
    • C-C.com
Re: Cuda Guy Project Update
« Reply #15 on: February 18, 2015 - 06:49:56 PM »
:burnout: nice burnout don,car sounds awesome and graite work al.don,what brand tires you running?
i wanna buy some stock in the company if your gonna keep frying tires like that...........  :smilielol:
The funny thing is those tires dont have very many miles on them, when I took it back to alans I noticed they had wore down quite a bit.  I need better tires for sure.  Most likely some drag radials by MT or Hoosier.
Don
Member Since January 14, 2002
« Reply #16 on: February 18, 2015 - 08:48:25 PM »
I like Nitto Drag radials 275 /50 fits well available from discount tire direct with free shipping
Offline DoNotChallengeHer
  • Drive It Like You Stole It !
« Reply #17 on: February 19, 2015 - 04:15:46 PM »
Don, Your gonna kick my Challlenger's butt coming back from the kick off party know. At least before I had a chance.  Now , I'm not messing with you with my little ole small block.  :smilielol:
« Reply #18 on: February 20, 2015 - 06:56:41 PM »
Jackie, look behind you.  Your butt is gone now.  If you get any skinnier, we will miss seeing you when you are standing in the tent.  315's Don
  • Pearl Harbor, HI
    • C-C.com
« Reply #19 on: February 21, 2015 - 08:40:25 PM »
Neil,
I'm going to go with a 15x10 rim and I'm looking at 325/50/15 drag radials, I have done some research here and on Moparts and seems all I will have to do is trim the inner quarter panel wheel lip to make sure there is no rubbing.
Don
« Last Edit: February 21, 2015 - 08:43:27 PM by The Cuda Guy »
  • Pearl Harbor, HI
    • C-C.com
« Reply #20 on: February 21, 2015 - 08:41:49 PM »
Jackie,
I was actually thinking about my redemption pass at Quarter Aces once I started to get used to the new power of the cuda!!!  LOL!!!  If your nice I will keep the race close!
Don
Offline StRoKeR
« Reply #21 on: February 22, 2015 - 08:00:15 PM »
 :working:
Member Since January 14, 2004
71' Dart - 9 second All Motor Pump Gas Street Car! Full Interior, Full Exhaust, Raced on Local 93! 3400lbs.
72' Challenger - 10.67 @ 127.78 All Motor on 93 pump gas! 3850lb street car (SOLD)
« Reply #22 on: February 22, 2015 - 09:34:38 PM »
Do you have the narrower 66-70 B body narrower diff ?
  • Pearl Harbor, HI
    • C-C.com
« Reply #23 on: February 22, 2015 - 10:06:59 PM »
Yes, it has a b-body specd dana.
Don
« Reply #24 on: February 23, 2015 - 05:58:58 PM »
I have never tried to fit a 325 but others have so if it works for them .... , larger diameter wheels such as 17" will allow wider tires too
« Reply #25 on: February 24, 2015 - 08:40:34 PM »
 :aussie:
  Alan, I'm well aware my butt is gone.  :bricks1:  But , I have an amazing Doctor. I'm gaining so weight. He knows what is wrong. I'm up to 88.3 lbs. Much better then the 75 lbs that put me in the hospital last summer.  :thumbsup:
« Reply #26 on: February 24, 2015 - 08:41:26 PM »
Jackie,
Don
  So, I get a head start ?  :poopoke:
Offline StRoKeR
« Reply #27 on: February 25, 2015 - 10:52:57 AM »
My Dana was a little shorter than b body specs. I rolled the lips with the butt end of a pool stick a floor jack and a heat gun.
  • Pearl Harbor, HI
    • C-C.com
« Reply #28 on: February 25, 2015 - 02:43:14 PM »
Thanks for the tip.  I figure I will just tape off the section I need to get rid of and take a die grinder to it and never look back.
Don
Offline StRoKeR
« Reply #29 on: February 26, 2015 - 10:33:20 AM »
Good luck man! Got any wheels in mind?
