Author Topic: Swapping headlights to LED?  (Read 4670 times)
Offline andben
« on: February 12, 2015 - 05:31:18 AM »
Guys, I know i've read on this forum that someone swapped the old sealed beam headlight to like Halo LED. Cant find it tho.
Someone got experience doing this? I think 5.75" is the correct size when looking for LED Halo beams?
Some advice for buying all 4 or just swap two of them.
All advice is appreciated!
Cheers from a cold Sweden!  :cheers:
e-body for life
Offline shawge
  • Zoiks!!
Re: Swapping headlights to LED?
« Reply #1 on: February 12, 2015 - 12:57:30 PM »
You are right, the Challenger uses 5.75" headlights.
Is this the thead?
http://www.cuda-challenger.com/cc/index.php?topic=67350.0
- Jerry
Offline andben
« Reply #2 on: February 13, 2015 - 03:46:21 AM »
Is this the thead?
YES! There is was! Appreciated!  :bigsmile:
e-body for life
Offline cuda lover
« Reply #3 on: February 13, 2015 - 03:05:34 PM »
« Last Edit: February 13, 2015 - 03:20:38 PM by cuda lover »
CUDA Lover
Offline andben
« Reply #4 on: February 16, 2015 - 02:50:12 AM »
I did that on my cuda
Straight swap of bulb
just wired it so the halo was on if ignition is on
only paid $29 for these bulbs http://www.ebay.com/itm/5-3-4-H5006-H5001-WHITE-HALO-HALOGEN-H4-BULB-CRYSTAL-CLEAR-HEADLIGHT-ANGEL-EYE-/231132005560?pt=Motors_Car_Truck_Parts_Accessories&hash=item35d08a84b8&vxp=mtr#ht_0wt_0
Sweet! Looks very good on your Cuda! I got a chally so I need 4 of them actually :)
Thanks for the update!
cheers
e-body for life
Offline cuda lover
« Reply #5 on: February 17, 2015 - 03:01:37 PM »
cheers
you don't have to do all 4 headlamps, maybe changing only the 2 low beams would look good, you could start with that
CUDA Lover
Offline RCCDrew
« Reply #6 on: February 17, 2015 - 03:08:19 PM »
I'm not a big fan of the halos, but how do they work?  Are they much better at night?  I was thinking of buying the $330 set but if these are a big improvement...
Offline cuda lover
« Reply #7 on: February 17, 2015 - 04:23:19 PM »
I don't think the halo adds to the brightness. It  is for looks or in my case I made them running lights for easier visiability of my car to others in the daytime.
CUDA Lover
Offline RCCDrew
« Reply #8 on: February 17, 2015 - 05:07:11 PM »
Sorry, I meant how do the headlights work overall compared to the factory halogen bulbs?
Offline roadman5312
« Reply #9 on: February 17, 2015 - 05:37:50 PM »
I've heard of using the halo's hooked to the park lamps, or as DRL's. We got them for the Toxic T/A build, I'm going to experiment using them as turn signals.  Just thinkin out loud.  ::)
Offline andben
« Reply #10 on: February 18, 2015 - 03:42:06 AM »
Someone on another forum said "now I can actually see in the dark" after installing LED H4 headlights... I think it will be a big difference. I hope so anyway, thats why Ill update them. I live in creepy dark Sweden.
You dont need to use the HALO's - just dont connect them to park lights.
e-body for life
Offline Katfish
  • 70 Challenger
« Reply #11 on: February 19, 2015 - 06:25:58 PM »
Interesting, following along
Offline GoodysGotaCuda
« Reply #13 on: February 19, 2015 - 07:04:28 PM »
I've had both style truck-lite LEDs in the Jeep I just sold. While they were very good lights they looked -extremely- out of place on the Barracuda. So I sold the lights after I sold the Jeep. The <5% of the time I'll be driving my car at night is not worth the aesthetics hit by running LEDs. :2cents:
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline RCCDrew
« Reply #14 on: February 19, 2015 - 09:39:12 PM »
These look like halogen bulbs but are LEDs. A little pricey but may be worth it. I drive home after car shows and races quite frequently at night.
