Digital Level
Author Topic: Digital Level  (Read 1778 times)
Offline daveh
Digital Level
« on: February 12, 2015 - 11:13:34 AM »
Hey guys,
I'm installing a TKO600 in my 71.  I'm looking for a digital level to measure the trans and driveshaft angles.  Would the digital level below work?  Others online are really expensive and then I found this possibility.  What do you think?  It's purely a street driven car no racing.  If not do you have any reasonable recommendations?  Thanks
http://www.homedepot.com/p/Husky-9-in-Digital-Level-THD9403/100653598
Offline Oldschool
  • Member Since 9-05-06
Re: Digital Level
« Reply #1 on: February 12, 2015 - 12:11:09 PM »
I don't why any reason it would not work...
Ken  --  In Georgia
Offline 73restomod
Re: Digital Level
« Reply #2 on: February 12, 2015 - 12:53:40 PM »
To avoid any problems it needs to be more accurate than +/- .5 degrees. That has a tolerance of +/- .1, so your gtg. Remember use the oil pan rail to set the angle for the trans, and the pinion snubber mounting pad for the axle. If your axle doesn't have one stick a joint in the pinion yoke and measure cap to cap. Don't forget you complimentary and supplementary rules and you should be gtg.
Offline daveh
Re: Digital Level
« Reply #3 on: February 12, 2015 - 01:52:51 PM »
Thanks guys I'll go grab that one.
Offline 360FISH
  • BS23H3B567746
Re: Digital Level
« Reply #4 on: February 12, 2015 - 03:49:01 PM »
If you have a smart phone there are apps that work great.  I have an old Android phone and have used it successfully.
1973 ‘Cuda   Semi-Pro Touring
360 SB - 518/OD auto tranny - FAST EZ EFI - Edelbrock Fuel sump - HHR fan
Hella H4 headlights on relays - 97 Dodge Avenger seats - Chin spoiler - Bumpers pulled in to ’72 offset
Build: http://www.cuda-challenger.com/cc/index.php?topic=74674.0
Offline roadman5312
Re: Digital Level
« Reply #5 on: February 12, 2015 - 03:53:49 PM »
Not sure about the level but when I was looking for an angle meter I found an app (free) for my I Pad. Saved me money.   :2thumbs:
Re: Digital Level
« Reply #6 on: February 12, 2015 - 06:27:28 PM »
Clinometer. Worked great for me.
Offline Kevin71
Re: Digital Level
« Reply #7 on: February 12, 2015 - 07:11:55 PM »
I have a TKO 600 also.  It is shimmed up 1 and half off the transmission support  bracket.  Did you have to shim yours up much and if so how much?
Offline Kevin71
Re: Digital Level
« Reply #9 on: February 12, 2015 - 08:58:22 PM »
http://www.harborfreight.com/digital-angle-gauge-95998.html
I bought one like this at Princes Auto( Canadian version of Harbour freight)  on sale for $20
