I recieved the speakers today. They really aren't much bigger than the stock ones.
For the center 4 x 10, I bought one of those mounting plates that allow you to mount 2 smaller speakers. Seller was Jerry Landes at " Moparmad57 @ gmail dot com " He had them waterjet cut to fit the center hole, then waterjet cut two 3" openings in them.
It looks ike the 4" speakers will fit just fine.
The new speaker (BOTH original and new, turned upside down to measure) is a smidgen taller, at around 3/8". I may have depth issues, but nothing that isn't insurmountable. I don't see it as a probem.
The outer grills that I bought off ebay, will work fine with an 1/8" aluminum adapter plate, it looks like. Just something simple with a 3" - 3 1/2" hole in the center and enough overlap to mount to the original mounting holes for the original speakers, with a bit of foam to fill any gaps.
Nothing fancy or hard to make.
I will probably end up mounting speakers in the kick panels as well. This isn't optimum, but sometimes one has to make trade off's for better sound and concealment.
I will end up with 6 speakers up front. 4 in the dash - left and right, and 2 in the kick panels, left and right. And 2 in the package tray. Maybe a woofer for the trunk? But not for now.
The new Kicker 4" speakers are NICE! 150 watt peak, 75 watt continous RMS. They will most likely NEVER see those numbers.
They have rubber surrounds, polyproplyene woofers and silk dome tweeters. They should last a long time, and exceed my expectations. The dome from the tweeter barley rises above the top. Most other speakers, they jut out an inch or more.
These should work well. I'm happy!
I will try to take pictures soon.
