Author Topic: 1970 Challenger Dash Lights  (Read 1519 times)
Offline 440-6 Challenger
« on: February 14, 2015 - 02:34:25 PM »
Looking for some troubleshooting advice.  My dash lights have always worked.  I rarely drive a night but a few months ago I noticed my dash lights stopped working.   All of them. All the gauges still work to include the clock intermittently. I thought it might be the dimmer switch since the dome light would work intermittently.  It stopped working also.
No blown fuse.  All dash wiring is solid.
Thoughts?
Offline OUTLAW
  • MASTER OF ALL THINGS MOPAR
  • I didn't say you can't RACE--I said you can't WIN
    • MOPAR-MADNESS  WEB/FORUM
Re: 1970 Challenger Dash Lights
« Reply #1 on: February 14, 2015 - 03:44:53 PM »
do your park lights work? they are together at the main light switch. If park lites work it is probably the dimmer switch . prob have to pull switch out of dash and check terminals with a test light
Offline dougs bs23
« Reply #2 on: February 14, 2015 - 03:54:14 PM »
the "spring" resistor in the dimmer may be corroded.  You can carefully take it apart and clean the corrosion off, then apply dielec. grease and reassemble it.   may work then.
« Reply #3 on: February 16, 2015 - 11:43:21 PM »
Thanks for the input.  I'll do some troubleshooting this weekend and share how the story ends.
« Reply #4 on: February 17, 2015 - 09:33:42 AM »
Most likely it's your dimmer switch.  Remove it and send it in to JS Restorations.  Jim will restore it and have it working like new.
Offline Slotts
« Reply #5 on: February 18, 2015 - 09:22:55 AM »
Thank you, Darren!  :2thumbs:
Jim
