Author Topic: mystery plug in....key in buzzer?  (Read 2052 times)
Offline HELKENN
« on: February 15, 2015 - 12:25:56 PM »
Hey guys im trying to find out what this plug in is for, its on the right side of the dash and it shares a yellow with the passenger door switch. i was wondering if it was for the time delay relay?? the wires are dark blue w/ white tracer and a red wire and 2 yellow wires with black tracers
Offline shawge
  • Zoiks!!
Re: mystery plug in....key in buzzer?
« Reply #1 on: February 15, 2015 - 01:58:32 PM »
Yes, key-in buzzer according to a 70 wiring diagram.
- Jerry
Offline HELKENN
« Reply #2 on: February 15, 2015 - 02:49:28 PM »
so does anybody remake these? will it affect any operations of the car or not?
Offline TelisSE440
« Reply #3 on: February 15, 2015 - 03:58:53 PM »
Hi, it's there so you don't forget your keys when leaving, when I bought my 70 Challenger, the former owner had it disconnected and nothing happened. When I painted and fixed the interior, I plugged it in and it had a buzzer sound whenever I had the key in the ignition and any of the two doors were open. Hope this helps...
Offline shawge
  • Zoiks!!
« Reply #4 on: February 15, 2015 - 04:43:26 PM »
No reproductions as far as I know.  Mine was disconnected too, ran just fine.
- Jerry
Offline TelisSE440
« Reply #5 on: February 16, 2015 - 03:25:54 PM »
I was searching ebay and found one, http://www.ebay.com/itm/MOPAR-70-E-BODY-CUDA-CHALLENGER-HEMI-L72-CODE-KEY-HEADLIGHT-BUZZER-RELAY-2983872-/151562997993?pt=Vintage_Car_Truck_Parts_Accessories&hash=item2349dbd0e9&vxp=mtr but he says he hasn't tested it. It's not a reproduction but a used item. You will find a lot of 71-73 relays which need some modifications to work properly...
Offline MirageCuda
  • 1974 Cuda
« Reply #6 on: February 16, 2015 - 07:57:39 PM »
Mine drives me nuts! I'm thinking of removing it.
Randy
1974 Plymouth Cuda
2006 Dodge Ram 1500 SLT
1991 Nissan Skyline GTR
2002 Subaru Impreza WRX
Offline walkAbout
« Reply #7 on: April 06, 2020 - 04:05:51 PM »
Hi,
I think that's why many peeps are disconnecting it. Mine is also disconnected (at the end of the steering column) and I tried yesterday, it works, but also before I start the machine. You say here that's normal, also the manual, but it's really annoying if you just go in plug in the key (OK, only with open doors) and this buzzer starts. Would be better, just if you switched off the engine and you leave the car. But I will connect it, as it was designed like this. No more key in, when doors are open.  :worshippy
CU
walkAbout
