Author Topic: how to aline 1972 front bumper  (Read 809 times)
Offline ff6849
« on: February 15, 2015 - 03:00:12 PM »
installing a front bumper is their secret to this, I cant quite get things to aline is there a particular order in which i should do this. any helpful hints would be appreciated.....
(__________]]]]]}~~~~
73 440 Cuda'
915 heads (mild head work, stock bottom end 10/9:1 compression)
A518 2600-2800 Stall
4.10 rear gear
TTI headers with 3' exhaust with  X pipe
comp XE274H cam
Hughes Roller Rockers
Holley Sniper EFI
Holley Street Dominator intake
MSD ignition
Re: how to aline 1972 front bumper
« Reply #1 on: February 16, 2015 - 10:30:11 AM »
What exactly is the problem?  Aligning my Challenger bumper was a PITA.  It was shifted over to one side too much.  Accessing the bolts after the bumper was on the car was tricky.  The factory must have had a fixture to get everything lined up perfect(for 70's standards) the first time.  Your 72 should be easier then my 73.  I had a huge inner bumper reinforcement to deal with too.
Offline twalker
« Reply #2 on: February 16, 2015 - 02:16:40 PM »
Just put mine on my 73 cuda, I installed the arms first, loose. Then the bumper and inner plate to the arms, snug.  Then positioned the bumper front to back side to side ( not a lot you can do side to side without shims or moving the bumper on the arms but not much room there either)until it measured right (get a second set of hands) and tightened the arms to the frame.
Admittedly I had practice when I was doing the body work mock up.
« Last Edit: February 16, 2015 - 02:18:37 PM by twalker »
Offline ff6849
« Reply #3 on: February 17, 2015 - 03:49:31 PM »
 aliened it side to side, than center up and down. tighten the inner brackets and work toward the out side edges. this worked better than trying to get everything perfect all at once.
73 440 Cuda'
4.10 rear gear
comp XE274H cam
Holley Sniper EFI
MSD ignition
