I am trying to determine which size front sway bar would be the best selection for my car. My 70 A66 340 Challenger is a street car but I want to get rid of some sway that I still have in the current setup.
I have decided that the next suspension change will be a larger front sway bar (then later in the year change out the shocks). But for now, I want to make a decision on the Hellwig solid 1-1/8" or the Hellwig tubular 1-1/4" for this car. What do you think would be the right choice?
Current Setup: Monroe shocks all around, 235/60/15's and 255/60/15's, stock front sway bar, 3/4" frame mounted rear sway bar, .92" torsion bars, 11/16" tie rods, new poly bushings and ball joints, #043 rear springs both sides (6 springs) and new alignment done last Spring (no specs).
From what I have read, the 1-1/4" tubular bar will be stiffer than the solid 1-1/8" bar but I am concerned that it might be too stiff for the front of this car. Summit shows the solid bar at $199 and the tubular bar at $175, so price is not an issue between these two choices. I am mainly concerned on which size would be the best choice.
I am experiencing the rear end sliding around when being aggressive around curves at lower speeds. This is one reason why I want to look into a change on the front sway bar. The other reason is that I am getting some sway left to right with quick movements in the steering even with the current dual sway bars.
Note: Possible future suspension changes: Single adjustable shocks, 1.06" torsion bars.
My current stock front sway bar passes through the k-frame. Do the larger aftermarket bars mount through or below the k-frame? Any pictures of these two hellwig bars mounted to the k-frame would be great help!
Thanks!
