Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Transmission and Drivetrain
(Moderator:
Chryco Psycho
rear 8 3/4 housing 741 /742 differences
« previous
next »
Print
Pages: [
1
Author
Topic: rear 8 3/4 housing 741 /742 differences (Read 648 times)
culp71
Full Member
on:
February 18, 2015 - 02:25:28 PM »
all,
I have a 8 3/4 with housing # 741
question is can a ring and pinion gear for a 742 housing be put in 741 housing?
reason being I have a perfect 741 complete rear end but it has 2.76 gears.
I want closest to original 3.23 but can only find similar ratios for the 742 housing.
will a ring and pinion gear sold for a 742 fit into 741, if not what's the differences.
thank you
Logged
burdar
Sr. Resident
Re: rear 8 3/4 housing 741 /742 differences
Reply #1 on:
February 18, 2015 - 02:44:26 PM »
This link shows the differences in the pinion gears. I do not believe they interchange. There are 3.55 and 3.73 gears available for the 741.
http://www.moparts.org/Tech/Archive/axle/1.html
Last Edit: February 18, 2015 - 02:47:53 PM by burdar
Logged
HP2
Resident
Reply #2 on:
February 18, 2015 - 02:56:59 PM »
No, they do not interchange at all. You must have a gear set compatible with the case casting number you are using. You could swap in an entirely different third member of any casting # with the gear set you want, however.
Logged
culp71
Full Member
Reply #3 on:
February 18, 2015 - 03:25:40 PM »
thanks for the info, I was afraid of that...
but one last search before I was just going to go with new Motive brand gear 3.55 for 741 case, and
I found an original 3.23 pinion and ring gear from a 741 housing on ebay!!
bought it, Yahtzee!!!
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
