Author Topic: correct 70-71 cuda tranmission cross member 340/727  (Read 886 times)
Offline culp71
« on: February 19, 2015 - 08:54:44 AM »
could someone post a pic of the correct transmission cross member for a 70-71 cuda 340 w 727 trans.
thanks
Offline anlauto
Re: correct 70-71 cuda tranmission cross member 340/727
« Reply #1 on: February 19, 2015 - 08:56:02 AM »
The cross members for 70-71 E Bodies are all the same regardless of engine size or transmission type :2cents:
Offline culp71
« Reply #2 on: February 19, 2015 - 11:30:44 AM »
so attached pic is correct and would fit correctly...
Offline anlauto
« Reply #3 on: February 19, 2015 - 11:38:28 AM »
Yup, looks good to me :2cents:
Offline culp71
« Reply #4 on: February 19, 2015 - 12:19:23 PM »
thank you!
« Reply #5 on: February 19, 2015 - 09:02:16 PM »
OK I may be wrong but I thought 70 had a different bolt spacing ?
Offline anlauto
« Reply #6 on: February 19, 2015 - 10:10:03 PM »
Far as I know the 73-74's had the narrower bolt pattern. I know for a fact, 70 & 71's are the same.  :2cents:
