Author Topic: Steering Column Disassembly Question  (Read 1255 times)
Offline FY1Cuda
« on: February 19, 2015 - 06:12:04 PM »
Reached an impasse:  I'm trying to remove the cylinder that has the shifter-lock-out lever on it so we can install the lower bearing upgrade.  The first picture shows the lever I want out of there.  The second photo shows how far I've gotten.  What do I do next to remove that inner cylinder?
Offline Katfish
  • 70 Challenger
Re: Steering Column Disassembly Question
« Reply #1 on: February 19, 2015 - 06:24:11 PM »
Watching........
Do really need to remove that?
Offline FY1Cuda
« Reply #2 on: February 19, 2015 - 06:28:09 PM »
Just figured it out.  That's a set screw in the second photo. It holds the cylinder in there.  The new steel bottom bearing fits between the outer column tube and the steering shaft.  That cylinder that has the shifter gizmo has to be removed
Offline anlauto
« Reply #3 on: February 19, 2015 - 07:41:02 PM »
I just took apart two columns today, but you beat me to the answer :drunk:
Offline FY1Cuda
« Reply #4 on: February 19, 2015 - 09:10:56 PM »
Thanks anyway.  I might have more questions before turning the steering wheel actually turns the wheels.
Offline CUDA JAS
  • vroooooom!
« Reply #5 on: February 20, 2015 - 08:57:57 AM »
Shoot me a PM with your email address and I can send you a great PDF document that details the teardown and assembly of a steering column.
I did not create it, but got it from a member here.
Jason
74 'cuda 360/727
Just call me a gearhead!
