Author Topic: New to site  (Read 5425 times)
Offline fc7vw9
Re: New to site
« Reply #15 on: May 12, 2015 - 03:19:50 PM »
original hood scoops, inserts, and gaskets, and installed
Offline anlauto
Re: New to site
« Reply #16 on: May 12, 2015 - 03:28:40 PM »
Is that FY1 or GY3...Hard to tell on my computer...either way...I like it !
Offline fc7vw9
Re: New to site
« Reply #17 on: May 12, 2015 - 03:40:09 PM »
NOS louvers, note the boxes and blue and white labels, boxes have a July 1970 date stamp, the white foam seal is very soft and small celled, pal/accorn nuts NOS, backing plates are original to the car and are stamped in galvanized sheet metal with a radius to the fender. Very different than the two different repros I have.
Thank you, GY3 single stage with a light buffing not to remove the "orange peel".
Offline fc7vw9
Re: New to site
« Reply #18 on: May 12, 2015 - 03:59:11 PM »
Back from paint shop black out process. NOS rocker trim installed using NOS clips and screws. Screws are partial thread with wax seal. The black out paint was matched to organisol. I have the laq. organisol, painted it to a donner, then worked with a local paint supply to get very very close. 33 different formula trys. 34 was it. It was also used on tail panel adjusted gun and patterns to get texture on tail panel. Some was also brushed around front and rear window opening.
Offline fc7vw9
Re: New to site
« Reply #19 on: May 12, 2015 - 04:14:03 PM »
tail panel with NOS lock, window black out. Front black out with restored headlight brackets, buckets, and NOS retainer rings. NOS head lights to follow.
Offline anlauto
Re: New to site
« Reply #20 on: May 12, 2015 - 04:19:06 PM »
Nice...The original rocker trim on a couple of 71 Cudas I've restored had welded studs as opposed to the screws shown in your picture. The screws are supplied with the replacement NOS trim package.
Offline fc7vw9
Re: New to site
« Reply #21 on: May 12, 2015 - 04:31:53 PM »
Thank you, Yes the studs were all the original welded studs the clips slide on to, the screws (only 2 per package) were used in front and rear of trim.
Offline anlauto
Re: New to site
« Reply #22 on: May 12, 2015 - 05:00:50 PM »
okay good :2thumbs: .....Restoration looks stunning..... :drool:
I'm kinda partial to 71's, and have a few restorations under my belt....Currently doing a 71 V code FC7 car... http://www.alangallantautomotiverestoration.com/71VCodeCuda.html
http://www.alangallantautomotiverestoration.com/PAST-RESTORATIONS.html
Offline fc7vw9
Re: New to site
« Reply #23 on: May 12, 2015 - 06:12:40 PM »
Looks like you have done more than a few. Its an obsession at this point. I think I should start a resto tread here now that I have the picture thing figured out.
Offline 734406pk
  • Andy
Re: New to site
« Reply #24 on: May 12, 2015 - 08:52:20 PM »
Very nice work!  :wow:
Offline mopar jack
Re: New to site
« Reply #25 on: May 12, 2015 - 10:18:30 PM »
Did the factory black out around the windows?
Offline fc7vw9
Re: New to site
« Reply #26 on: May 13, 2015 - 09:49:10 AM »
This cuda and a few others I have owner were blacked out around front and rear window. All were white or yellow. But the brown 71 Hemi Challenger at MATS was also blacked out around front window at least, very long run to a puddle. I will Post Pictures. When I find them.
Offline fc7vw9
Re: New to site
« Reply #27 on: May 13, 2015 - 10:30:50 AM »
Here is a link to a yellow convert. not mine, my teardown pics are on my ex wifes computer :banghead:. But you can see the black runs down the a pillar. Mine was very much the same. https://www.flickr.com/photos/15695344@N00/9606139625/in/album-72157635254103467/
