Author Topic: Trans temp sender location  (Read 1107 times)
Offline crash340
« on: February 20, 2015 - 11:59:06 PM »
Team,
What is the best place to install the trans temp gauge sender??? in the side wall of the Pan??
Greg
73 Cuda
Brisbane, Australia
Offline 734406pk
  • Andy
Re: Trans temp sender location
« Reply #1 on: March 09, 2015 - 10:58:25 PM »
Yes the pan would be best. You will get the sump temp. 2nd best would be in the front cooler line to the trans cooler. The fluid temp here will be somewhat higher than the sump.
Offline crash340
« Reply #2 on: March 10, 2015 - 04:45:09 AM »
Thanks 734406, appreciate it.
Greg
73 Cuda
Brisbane, Australia
« Reply #3 on: March 10, 2015 - 02:54:06 PM »
I used to take the trans tube n stick out of a 70's motor home. It was in the stick, made things easy,  then the right ohm gauge or factory gauge. But I'd put it in the pan like the newer ones came with now a day
« Reply #4 on: March 13, 2015 - 11:17:22 PM »
If you put it into the cooler line make Sure the sensor doesn't restrict the cooler line flow , so use a tee & space it back from the line , if the line is restricted you may be causing the problem !
Offline crash340
« Reply #5 on: March 14, 2015 - 06:09:24 AM »
I think I'll just run it into the side of the pan next time its off. I dont have a gauge right now but would like to just be monitoring it
Greg
73 Cuda
Brisbane, Australia
