Author Topic: A little confusion about indicator lens weld in.  (Read 657 times)
Offline challenger_73
« on: February 22, 2015 - 07:48:10 AM »
Hey all,
I'm a little confused about the indicator weld in on the rallye dash. Are the lenses welded to the black shroud or to the white tubes. I was looking at a previous post and this is what i saw. My car is a 1973 Challenger.
Offline Katfish
  • 70 Challenger
Re: A little confusion about indicator lens weld in.
« Reply #1 on: February 22, 2015 - 08:52:23 AM »
Mine are in the bezel, tube presses up against the bezel.
Offline bc3j
« Reply #2 on: February 22, 2015 - 09:41:07 AM »
Mine are the same as Katfish. From the picture above, I think the brake indicator should be far right.  Turn signals are together to the left. From left to right should be: left turn, right turn, brake. My car is a 70.
Offline anlauto
« Reply #3 on: February 22, 2015 - 11:01:36 AM »
The lenses go on the bezel, not the tubes :2cents:
« Reply #4 on: February 22, 2015 - 12:45:43 PM »
Bezel  it is! Thanks.
