Author Topic: 70 base car with 383 four speed with some tail problem  (Read 19570 times)
Offline Ifixmycarmyself
Re: 70 base car with 383 four speed with some tail problem
« Reply #45 on: December 27, 2015 - 05:46:25 PM »
Awesome Progress... Been there & know what it takes... Good to see your boys involved.. :clapping:  My only warning, you might regret that deep oil pan.... I'd suggest a Hemi style pan & a skid plate welded to the K member..
Thanks  :worshippy
Bought the engine with a B-body oil pan so this is some old stuff i just use for dust protection. I will have to buy a new oil pan and pick up.
« Reply #46 on: December 27, 2015 - 05:55:45 PM »
Just want to post a small clip on how I tried to fix the roof dents. Roof was in bad shape with a lot of dents.
Have no idea why text says -no longer available- .... but just click the text and video starts  :)
! No longer available
« Last Edit: December 27, 2015 - 06:05:02 PM by Ifixmycarmyself »
Offline Challenger in NC
« Reply #47 on: December 30, 2015 - 04:17:26 PM »
Looks fantastic. Have enjoyed the videos for the past year or so, wish I had the patience and skill to do the same on my car.
« Reply #48 on: December 30, 2015 - 07:07:36 PM »
Thanks for kind words! I'm sure you can do the same on your car. There is so much help, hints and support from good people on this forum, thanks to that I sincerely believe that everyone can do it. Do not hesitate, just do it!
Offline HP_Cuda
  • Mopar or No Car!
« Reply #49 on: January 01, 2016 - 03:20:02 PM »
Great work there! Time and patience gets the job done every time!
I am interested in your next vid on oil canning.
« Reply #50 on: January 02, 2016 - 05:05:10 AM »
Here is the next clip where I try to fix the oil canning dent on the roof. The idea is to restore the stability and tension in the roof, which is completely gone in several spots. Sadly camera stopped to record but there where other spots to fix and i used the same procedure. Roof is not entirely done in the clip. I have also done some lead soldering to right side and I will go over the roof again with hammer and dolly.
« Last Edit: January 02, 2016 - 05:12:39 AM by Ifixmycarmyself »
Offline cudamadd
    • cudamad157071@gmail.com
« Reply #51 on: January 02, 2016 - 08:18:05 AM »
Wow great job .  Doing a awesome job in a small garage ,How do you do it ?    :clueless: great to see a family project .cannot wait to see more pictures and videos . To  see some of the made repairs  made me sick . I had the same thing once  . Any way well done so far  :cheers: :aussie:
Go 4 a spin Ya Why Not.
« Reply #52 on: January 02, 2016 - 01:38:47 PM »
Thanks! Yes, the small garage.... stumbling over cables and hoses, can only work at one side at the time and so on.
At times I almost loose my mind,  :pullinghair: but then i take a deep breath or a cup of coffee and then I get back to work. But we are planing to build a new garage.
Offline rUNCHARGER
« Reply #53 on: January 02, 2016 - 02:27:38 PM »
I hear you: My place is jammed as well, really have to be careful to not damage the cars.
Sheldon
Offline TelisSE440
« Reply #54 on: January 02, 2016 - 03:48:46 PM »
The work you did on dents. That's what I call professional !   :2thumbs: Most auto shops just put filler and continue...
« Reply #55 on: January 03, 2016 - 04:36:00 AM »
Sheldon
Beautiful car!!!
« Reply #56 on: January 03, 2016 - 04:53:18 AM »
Thanks! Yes, thick layers of filler is maybe ok on show cars, and it is used a lot ( :eek4:) but will eventually crack on cars that are driven. The dents in the front of the roof was not visible, only a small crack was, but under the paint there was 1/4" of filler. The crack was down to metal, which had started to rust underneat the filler.
Offline 'Cuda Hunter
  • Tastes Like Chicken
« Reply #57 on: January 03, 2016 - 11:13:52 AM »
I am thoroughly enjoying this thread.  your videos are awesome!
Sucks that the camera went dead on the oil can routine.  But i got the gist of the process on the follow up.  :2thumbs:
« Reply #58 on: March 04, 2018 - 02:27:41 PM »
Trying to save a pair of rusted and dented old fenders.
Restortion continues... slowly.. Here are some pics of my fender restoration. First I tried to fix the dentet front with a bezel as model for the shape. made some patches and disassembled the whole fender. Making some new parts and removing rust with a mix of water and citric acid. Last picture is the patched fender with some black guide coat to easier spot and fixing dents.
« Last Edit: March 04, 2018 - 02:35:14 PM by Ifixmycarmyself »
« Reply #59 on: March 04, 2018 - 02:52:34 PM »
Made also a small video. but I struggle to get the url correct here...
« Last Edit: March 04, 2018 - 02:55:18 PM by Ifixmycarmyself »
