Author Topic: converting to 134 ???  (Read 861 times)
Offline reborn73
« on: February 22, 2015 - 08:47:33 PM »
What do I need to change/do to convert to 134A?   The system is apart for an engine rebuild so now is the time to do it.
What do I need to get?
Re: converting to 134 ???
« Reply #1 on: February 22, 2015 - 09:57:24 PM »
What's a 134A?
Offline AARTA340
« Reply #2 on: February 22, 2015 - 10:15:36 PM »
I believe he is referring to conversion of the older R12 refrigerant system to the newer R134 A refrigerant that is the standard for now. :cheers:
Offline dougs bs23
« Reply #3 on: February 23, 2015 - 06:16:26 AM »
I believe there are conversion kits  that give you all new seals, o rings and 134 oil that will all need to be changed out.  may have to also convert all the Schrader valves as well
Offline roadman5312
« Reply #4 on: February 23, 2015 - 06:39:09 AM »
New drier and expansion valve ( most of which today are 134a compatible. ) Flush system, get all oil out of compressor then use PAG or ester oil. Change all O rings replace with green HNBR Orings.
Offline DocMel
« Reply #5 on: March 01, 2015 - 09:30:50 AM »
The conversion, as already noted, is much more than changing out the coolant and a few valves.  Stay away from the "over the counter" kits.  I would have it professionally done as many major components will need to be replaced with new ones, the system needs to be airtight, everything working and pressurized correctly, etc.  Your compressor might need rebuilding or replacing, who knows at this point
Most shade tree conversions never turnout working correctly
Offline AussieMark
« Reply #6 on: March 01, 2015 - 10:27:50 AM »
Check with Classic Auto Air they do upgrades or will use OEM parts what ever you want, in my opinion they are the best.
