Author Topic: Steering shaft  (Read 860 times)
Offline WithoutRemorse
Steering shaft
« on: February 22, 2015 - 10:24:10 PM »
The steering shaft in the column is trashed in my car, is it possible to just change that shaft, or do I have to change the entire column?
Re: Steering shaft
« Reply #1 on: February 22, 2015 - 10:28:07 PM »
Can you elaborate by what you mean that it's trashed?
Perhaps it's salvagable.
Re: Steering shaft
« Reply #2 on: February 22, 2015 - 10:35:08 PM »
Sorry, I should have explained haha. The power steering box was removed years ago and a manual installed. Because the shaft wasn't long enough with the manual box, the shaft was cut, and a piece welded into the middle of it to lengthen it. It looks horrible. After installing the new box, i could always cut out the extension and weld the two pieces back together, but I won't. Rather replace it if possible.
Re: Steering shaft
« Reply #3 on: February 23, 2015 - 01:56:27 AM »
It is easy to replace the shaft. You just have to fine one is all.  They are around
