Author Topic: New Autometer Gauges Not Working  (Read 1566 times)
nivvy
« on: May 11, 2005 - 04:00:39 PM »
I dont understand...I have no power to my dash or any of my guages....dont understand.....
Does anyone have any advice on installing a whole new set of gauges....ripped out all the old ones....and tried hooking up the new ones and nothing works.... :pissed:
speedometer
voltmeter
oil press
Fuel level
water temp
etc....
I prewired the guages up to a custom panel and then tried wiring them up and nothing works...where did i go wrong???
8 Pack
Offline HemiDog
  • Do not Assume!
    • Hemi Dog
Re: New Autometer Gauges Not Working
« Reply #1 on: May 11, 2005 - 04:03:42 PM »
Are you sure you have them grounded?
Also you need to make sure you have 12v going to them instead of the stock 5v.
nivvy
« Reply #2 on: May 12, 2005 - 11:33:07 AM »
Im pretty sure i figured it out....as soon as i hooked up the old dash/voltmeter i got power back to the fuse panel....i looked at the factory wiring diagram and power routed through the voltmeter to the fuse panel...so i believe if i hook up the factory wires to my autometer volt meter and run a ground to the dash power will get back to the fuse panel...i believe when you screw the factory dash down it creates a ground....
and send power to the fuse panel...
8 Pack
Offline HemiDog
  • Do not Assume!
    • Hemi Dog
« Reply #3 on: May 12, 2005 - 12:21:51 PM »
The factory dash is plastic though.
All of my autometer guages have thee basic wires in common.  Red (12v fused protected power), Black (ground), and White (12v for lights).  With these three you get power running and in case of the voltmeter, it is completely hooked up.  You need to make sure the ground is secure to a metal surface that is actually grounded to the battery.  The red wire you should be able to tap into any ignition activated 12v wire but make sure it isn't a wire that will power a lot of accessories.  It will cause the wire to get hot if too many amps are drawn.  The white one can hook into the factory lead to the dash lights.  The most common problem is the bad ground.  You need to make sure you have the wire touching a metal surface and not just sitting on a painted surface.  I like to use the areas where the dash frame bolt to the car for my grounds.  That way you aren't creating any new holes with screws or bolts.
As for each individual guage, the remaining wires just hook up to the corresponding sending unit.
When you turn the power on the gauges should cycle, even with out the sending units hooked up.
nivvy
« Reply #4 on: May 12, 2005 - 01:49:52 PM »
it still aint working.........when i said i put back in the original voltmeter and screwed the dash down it works......im so confused and frustrated...on the autometer voltmeter i turn the key and the voltmeter registers but no power is still not going down to the fuse panel and the car wont even make a sound to try to crank over.....
8 Pack
« Reply #5 on: May 12, 2005 - 03:07:25 PM »
OK guys,
  You are losing me here. Sorry. The original gauge was an ampmeter. That meant all current went thru it. If you replaced it with a volt meter, that would explain it. Is that what you did 8 PACK ??? And again, on the originals gauges, the dash frame was ground. They had to be attatched to work. Let me know more facts. I can help you.
Offline dilligaf
    • Willcraft Technologies Ltd.
« Reply #6 on: May 12, 2005 - 05:11:21 PM »
8 PACK,
I know you are in the heat of the problem,
But  Iwould really like to see some pics of what it all looks like.
I am in the process of doing same,
dilligaf
2 1974 'Cuda's
1 1973 Challenger
nivvy
« Reply #7 on: May 12, 2005 - 10:22:22 PM »
got it all figured out......i just tied the red and black factory ammeter wires together at full power now... :burnout:
8 Pack
Offline LEMOOREACE
  • I was a llama, but I have since evolved.
« Reply #8 on: January 25, 2013 - 12:37:19 PM »
I am planning to install a new aftermarket dash cluster with Autometer gages and I need to know what power wire is best to tap into for the bank of gages, and what to do with the old ammeter wires....   linking the two wire ends together worries me with all of the talk about fires igniting from the ammeters...      :horse:
