Author Topic: gasket? behind power break booster  (Read 1623 times)
Offline cuda lover
« on: February 25, 2015 - 10:00:02 AM »
I was replacing my power assist break booster, on the old one I took off he had some kind of gasket / thin membrane between the canister and firewall, It was mostly destroyed after 40+ yrs.
the new one did not come with that. Is it needed?
CUDA Lover
Offline anlauto
Re: gasket? behind power break booster
« Reply #1 on: February 25, 2015 - 10:13:16 AM »
Needed? Probably not..."a good idea? " always.
You can get a new one for about five bucks from Detroit Muscle Technologies :2cents:
« Reply #2 on: February 25, 2015 - 10:15:31 AM »
There is a reinforcement plate that attaches to the back of the booster.  Then there is a foam gasket that goes between the reinforcement plate and the firewall.  You need the gasket there to keep water and possibly fumes out of the interior.  You can buy complete body gasket kits from DMT(Detroit Muscle Technologies)  If you don't want to buy a whole kit, you could probably make a gasket yourself.  If you plan on removing/replacing other components, the gasket kits will come in handy.  There was also a gasket between the master cylinder and the booster.
Offline cuda lover
« Reply #3 on: February 25, 2015 - 11:42:36 AM »
Thanks for the info I will just have to work up to crawling back under the dash to remove it to put the gasket in and replace
I dd not see a reinforcement plate that was on the back of teh booster I took off.
CUDA Lover
« Reply #4 on: February 25, 2015 - 12:08:13 PM »
Offline cuda lover
« Reply #5 on: February 25, 2015 - 12:22:40 PM »
Burdar,
thanks for the pictures, I orderd the gasket and will be getting it in a week. I guess I will be crawling back under the dash.  :crying:
CUDA Lover
Offline cuda lover
« Reply #6 on: February 28, 2015 - 09:23:41 AM »
In the picture you posted one side of the plate is shorter the the other with the mental bent over. In the picture the shorter side is on so that if it was on the car the shorter side would be away from the drivers side fender (or more to the middle of the car), is that the way I should install it?
CUDA Lover
Offline HP_Cuda
  • Mopar or No Car!
« Reply #7 on: February 28, 2015 - 02:44:24 PM »
This might help.
« Reply #8 on: March 02, 2015 - 10:54:48 AM »
The band clamp is at the top of the booster.  That would make the longer side of the bracket on the drivers side of the car.
Offline cuda lover
« Reply #9 on: March 03, 2015 - 12:55:30 AM »
Thank you. It was not clear from the exploded diagram it showed both sides equal
CUDA Lover
