Author Topic: hemi install from below question  (Read 4173 times)
Offline cordodge
« on: February 25, 2015 - 11:17:17 AM »
hey, im sure some one has done this, but I measured my motor and it's 29-1/2 inches wide, about a 1/2" wider than the narrowest part of the engine bay. not sure if there is some little trick to sneak it by so I don't have to remove a valve cover. I was thinking of some how adding something on the engine cart that I could tilt it to clear and then once it does even it back out. :dunno: any help or ideas would be appreciated.  bruce
1970 challenger 95% done
1969 roadrunner in progress
1969 D-100 13,000 mile truck
1969 L-700 tilt cab in progress
2007  Dodge Ram 4x4
2017 hyundia Santa fe ultimate
1977 VERY UNDERSTANDING WIFE !! 😇
Re: hemi install from below question
« Reply #1 on: February 25, 2015 - 11:33:32 AM »
I thought the factory installed the engines with the valve covers off.
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #2 on: February 25, 2015 - 11:35:07 AM »
turn the engine a tad and that will help clear the covers on the shock towers. at the shop I put the hemi's in from the bottom with out removing the covers. But those were with stock covers. I would have to look at the cast covers to see if they are any taller that the steel covers.
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline cordodge
« Reply #3 on: February 25, 2015 - 12:11:23 PM »
Hey Dave, thanks for the info. yeah not sure but they do look a little taller, I need about a 3/4" to make it but an inch would be more comfortable for sure that's why I was thinking if I built a cart that would tilt it may work. I could also pick up the car on a bit of an angle the opposite way of the tilted motor to help. I know Alan installs them the way you do but that is probably stock covers as well.
thx Bruce
2007  Dodge Ram 4x4
« Reply #4 on: February 25, 2015 - 12:37:14 PM »
Why not just take the valve covers off? Are they difficult to put back on in the engine bay?
Offline roadman5312
« Reply #5 on: February 25, 2015 - 12:38:56 PM »
 :popcorn:
Offline cordodge
« Reply #6 on: February 25, 2015 - 02:03:31 PM »
hey dodj, yeah it's not that big of a deal to take them off may just have to remove one (pass side more room) just don't want to have any leaks as it looks like it is sealed up nice but your probably right.  bruce
2007  Dodge Ram 4x4
Offline JS27N0B
  • Member since Jan 28th 2003.
« Reply #7 on: February 25, 2015 - 08:41:19 PM »
Stock covers just clear, if they are not stock i think you would have much less chance of scratching something by removing the covers first.
2013 Tige' RZR 343hp
« Reply #8 on: February 25, 2015 - 11:59:21 PM »
Be safe than sorry. Remove P/S valve cover.
As it nears shock tower apron, Keep an eye on clearance.
Use a jack underside at the trans to slightly tilt P/S if necessary as it's about to clear.
Offline cordodge
« Reply #9 on: February 26, 2015 - 07:58:11 AM »
Hey thanks for the input guys, your right It makes sense to remove the pass/side cover for clearance, I would feel pretty stupid if I scratched something.  thx bruce
2007  Dodge Ram 4x4
Offline 69ChargerRT
  • Its the car, right? Chicks love the car. - Batman
    • Daisy - My 1969 Dodge Charger R/T
« Reply #10 on: February 26, 2015 - 10:14:46 AM »
if his avatar is any indication, im not so sure hes going "stock"  :lol:
Offline 67vertman
  • Member since 9-23-2005
« Reply #11 on: February 26, 2015 - 02:15:48 PM »
Yeap, we all missed that one.  :bricks1:
Offline George72Cuda
« Reply #12 on: February 26, 2015 - 03:39:48 PM »
I installed a Generation III 6.1 Hemi in my 1972 Cuda. I had the transmission installed and put all of that on the RMS suspension system, then used a gantry crane to lift the body and installed all as one unit without any problems. Did have to change the transmission tunnel some for the transmission fit.
Offline roadman5312
« Reply #13 on: February 26, 2015 - 04:04:24 PM »
                    Sounds like a sweet install. Got any pics ?  BTW welcome to the board.
« Reply #14 on: February 26, 2015 - 04:16:09 PM »
I tried to attach some photos, but guess they are too large, will have to figure out how to make them smaller.
