Author Topic: Borg & Beck Clutch  (Read 1747 times)
Offline 300
  • 69 chevelle,67chevelle , 70 barracuda
Borg & Beck Clutch
« on: May 11, 2005 - 06:58:08 PM »
Hello  What is a Borg & Beck clutch, It is about 13 inches dia . can,t find any other #,s I,ve got one but don,t know what it is out of. Are they any good, Would they work on a 833 trans, what would be a good bell housing for it.  340 motor Thanks Terry
Offline OUTLAW
  • MASTER OF ALL THINGS MOPAR
  • I didn't say you can't RACE--I said you can't WIN
    • MOPAR-MADNESS  WEB/FORUM
Re: Borg & Beck Clutch
« Reply #1 on: May 11, 2005 - 08:29:53 PM »
Most B&B clutches use 3 flat fingers with roller fulcrums yess will work with 833 as that is what i been using the other options are diaphram and Long style Diaphram is exactly that a slightly cone shape that flexes to release and engage Long style is also 3 finger but usually long skinny 3 fingered and uses cantelever to engage and disengage
Offline 300
« Reply #2 on: May 11, 2005 - 08:37:33 PM »
Thanks Outlaw, are they a fairly common clutch in 4 speed mopars, what would be a good bell housing. Thanks
Offline 4Cruizn
  • HEMI FISH
« Reply #3 on: May 11, 2005 - 10:57:03 PM »
Actually I believe them to be one of the better setups!!
« Reply #4 on: May 12, 2005 - 01:15:40 AM »
Borg & Beck are standard equipment in Mopars for the most part , FWD & Deisel are different , a factory belhousing will be fine if you can find one , small blocks aer easier to get , a Mcleod blashsheild will work also & Keisler has a decent big block bel too
Offline OUTLAW
« Reply #5 on: May 12, 2005 - 02:24:41 AM »
A B&B is the best setup and the only reason to run a diaphram would be if you wanted to reducce pedal pressure for your wife or daughter ...I dont recommend it . As far a belhousing I run a Anson scattersheild with block saver...I dont think they are available any more so either one of the ones CP mentioned or a Lakewood ....I'm not a big fan of stock cast iron bellhousings (if you ever saw a flywheell go thru one you would understand )
Offline 300
« Reply #6 on: May 12, 2005 - 04:01:29 AM »
This clutch will be for a 340, I have a cast bell, maybe i should look for a better bell ??? Thanks Terry
Offline BB73Challenger
« Reply #7 on: May 12, 2005 - 07:50:17 AM »
I too have the B&B setup and left it.
My left leg is now stronger than the right, but it is superior.
Jeff from Cleveland, Ohio
