Author Topic: Mopar transmission guru's needed - Fitting a 47RH behind a big block  (Read 1456 times)
Offline Aus_Cuda
I've read people saying the 47RH can only fit behind the cummins v10 diesel, which is where it was fitted from factory.
Now I will be using an Ultra Bell bell housing adapter on the trans to make it fit behind a big block so the factory bell housing will be getting cut off.
Looking at the front pump of the 47RH it looks exactly the same as the 46RH. The ultra bell uses the front pump 7 bolts to mate up to the trans.
Is this the only thing I would need to do to make the 47RH fit ???
I'll be buying a new torque converter to suit my application so thats not an issue. I also have a spare 46RH case and overdrive housing if needed.
Offline ff6849
Re: Mopar transmission guru's needed - Fitting a 47RH behind a big block
« Reply #1 on: March 13, 2015 - 12:15:08 AM »
http://www.jvxracing.com/Adapters.htm
this is what I am getting ready to use,
(__________]]]]]}~~~~
73 440 Cuda'
915 heads (mild head work, stock bottom end 10/9:1 compression)
A518 2600-2800 Stall
4.10 rear gear
TTI headers with 3' exhaust with  X pipe
comp XE274H cam
Hughes Roller Rockers
Holley Sniper EFI
Holley Street Dominator intake
MSD ignition
